Thread: Questions
    Apr 2009
    204
    Questions
    My Setup:
    -Revo VXL
    -Stock Electronics/Motor
    -2 Promatch Racing 1600MAH Packs
    -Mini Quake Heatsink
    -Parallel Connector
    1. What is the pinion that comes with the Revo out of the box and the optional pinion?
    2. What is a good pinion and spur setup up for good top speed and reduce temperatures.
    3. I have an intengy fan that measures 2.5cm x 2.5cm any ideas on how to mount it on the esc somewhere an how to connect it.
    4. I have cut 2 holes on the top, 2 holes left and right on the top, cut the windshiled, and back windshield. Does anyone have any more ideas on cooling?
    5. After a run my batteries are smoking hot (barely touchable) is this normal?
    Thanx
    Jun 2009
    Western australia
    514
    1. IN THE MANUAL!
    2. IN THE MANUAL!
    3. duno, you can connect it to your RX
    4. is there any body left?!? you could run without a body
    5. yup
    GARAGE
    e-revo, ME-revo, micro-t, slash, DX3S
    Jul 2008
    Ontario,Canada eh!
    1,166
    Quote Originally Posted by concreat
    1. IN THE MANUAL!
    2. IN THE MANUAL!
    5. yup
    Hahahahaha lol
    RC RUNS IN MY BLOOD!
    R
    E
    V
    O
    May 2009
    N/A
    297
    GEARING, GEARING, GEARING, GEARING CAUSES HEAT IN A ELECTRIC CAR/TRUCK!!!!!!!!!! A TEMP GUN IS A MUST WHEN RUNNING ELECTRIC, BECAUSE YOU HAVE TO KNOW THE TEMPS AT ALL TIMES, otherwise your magnets will come loose in the MOTOR and your day is done!!!!! A large spur/small pinion=more torque/less speed/less heat, a small spur/large pinion=less torque/more speed/more heat. The stock spur and pinion set-up is a 50 tooth spur ansd a 28 tooth pinion, the optional pinion is 25 tooth. These are the same pinions that the RUSTLER, STAMPEDE & BANDIT VXL use.
    ERBE+TEKIN RX8+MAXAMPS=TO TOUGH TO TAME!!!!
    Jul 2009
    SOUTH OF THE MASON DIXON LINE
    145
    PICK UP TRUCK,A BLONDE & A BASSBOAT & 80%.
