Page 5 of 5 FirstFirst ... 345
Results 161 to 174 of 174
  1. #161
    San Diego, CA
    85
    Quote Originally Posted by Ranz View Post
    Came across these while googleing. The erevo guys reckon they work great.
    http://www.hpp-germany.com/factory-s...and-center-nut
    They look really nice!
    Have you contact them for overall cost to the US?
    Summit; ERBE; E-Slayer; MERVs
    Wraith; AX10; RX10
  2. #162
    Nov 2009
    Busselton, Australia
    227
    Haven't contacted them for postage price yet
  3. #163
    20,106
    Prices are not posted on the website? I was sure I saw them a while ago.
    Alt-248 on the number pad = į
  4. #164
    RC Turnbuckle Jr. rjm2519's Avatar
    Feb 2008
    Fl
    3,062
    Looks like 44.95 euro or around $56, kind of steep no? Plus shipping and taxes/duties.
    Donít handicap children by making life easy
  5. #165
    Aug 2012
    447
    Three years later n newbies like me still find these type of threads extremely useful...keep the knowledge flowing folks...
    N traxxas: do u not see the needs of ur customers?
    Anyways...thanks for the info guys...
  6. #166
    RC Racer ZUMA's Avatar
    Aug 2010
    Chicago, IL
    195
    This wheel slop is nasty and read thru this mod. Does not sound bad, nice mod. My question is how is it holding up and is there any other mods out there that do a better job of getting rid of slop? Was also thinking about going with the wheel hubs hpp germany makes but this mod would be so much cheaper but the hpp hubs do look nice.
  7. #167
    Dec 2003
    Dekalb, IL
    1,786
    Old thread, but don't see the alternative I'm now using on two of my revos.
    Originally, I tried milling steel nuts down to use as inserts. That worked ok, but regardless how much locktite I put on them or how tight I got them, they would work loose and fall off.
    Then I found the original e-savage 17mm hex's. They were the same ID as revo axles at the pin. I would use those with HPI's flanged nuts. Then I snapped an axle and lust my hub. I was no longer able to find the HPI e-savage hex, so I created an alternative out of the traxxas 17mm hubs.
    I cut the hub off flush with the hex, then use the HPI nut on the axle like normal. Works perfectly and no wobble ever.
    Expert rigging at it's best!
  8. #168
  9. #169
    Aug 2010
    Chicago, IL
    195
    Nice, thanks for the info. I missed that one
  10. #170
    Mar 2015
    105
    For less than $10 parts it's the easiest way to eliminate wobbling. I used a angle grinder with a 4 inch cutting disc on it. Then smoothed out the cut with a 2 inch 3M Roloc Scotch-Brite disc.
  11. #171
    Dec 2003
    Dekalb, IL
    1,786
    Quote Originally Posted by erevodriver View Post
    I used a hack saw with a metal cutting blade, then a dremel to clean up the center a bit. Well, on the first set. On the 2nd set, I used my mini saws-all. Time taken, like 45 seconds per wheel. lol
    NASCAR HERE I COME!
    I read in another thread posted above that this mod had issue with RPM wheels. Not sure what wheels he used as I've used RPM revolver 3.2" wheels with out issue as well as traxxas non-offset 3.8" wheels, traxxas 3.8" geode wheels and SRC wheels.
  12. #172
    26
    I know that this is an older thread, but I thought that I'd share my version of this mod. I used a different 5mm insert.
    I started with this 5mm wood insert that I bought from McMaster-Carr:
    I drilled out the 17mm hub using a 5/16" bit. I didn't drill through the hub. I drilled down approximately 0.4" If I do it again, I'd drill down just a little bit less.
    I threaded the insert onto a 5mm bolt and put it in my drill press. Using a metal file and reduced it down to 5/16" to fit snugly inside the hub.
    And here's the final product:
  13. #173
    Dec 2003
    Dekalb, IL
    1,786
    I recently did the cut off mod and used HPI flange nuts on my ERBE, but found that I wasn't able to tighten the nuts down far enough to grip the wheel. I had to countersink the back of the nuts a bit, then it worked fine. Not sure why I didn't have that issue on my other 2 revo's. Perhaps HPI has more than one kind of the nut, don't know.
    Hub:
    Countersink on the back of the nut:
  14. #174
    Dec 2015
    Denmark
    113
    Finally found this thread, hopes it will work out as well for me as for you guys... I did however mid the length og the insert, and was lazy enough not to measure the thread on my revo, so went ebaying. Ordered. 10/12/16 mm length inserts. 2-3pounds a bag with 20 in them. . So just waiting for the china postman to go on his bike an deliver ��
    And wondering which way to go, i see pro and cons on either fix... 1 the locktite fit on axle(leaning most to this). Or the pressfit in axle and screw on.
    Link for you guys to buy thoose inserts.
    http://www.ebay.co.uk/itm/3223777076...%3AMEBIDX%3AIT
    http://www.ebay.co.uk/itm/1318781651...%3AMEBIDX%3AIT
    nitro rusty, t-maxx and 2 revo 3.3's. Slash 4/4 bl
