Page 1 of 2 12 LastLast
Results 1 to 40 of 45
Thread: Spur Gears
    Aug 2009
    12
    Spur Gears
    Anyone have any idea why I keep chewing through Spur gears? I've had the Slash for about a week now and have went though three of them. Obviously its motor alignment, but I did the paper trick for alignment and even went to the local shop and had them set it. Still eating them up.....Any ideas. My buddy has a back yard track and their is lots of sand at one end, resulting in lots of spinning. Not sure if this has something to do with it or not. Ani ideas? Thanks guys. P.S. All stock
    48
    how is the spur being damaged? does it get chewed up right after you land a jump? if so loosen your slipper a touch. is the pinion in good shape? if it has bent/rounded teeth then replace it as well as the spur... incorrect mesh causes rounding/bending on BOTH the pinion and spur. Does the spur wobble a bunch? a bent top shaft will ruin spurs...
    Just breaking loose the tires will not eat a spur...if it did I'd be repalacing spurs every few minutes
    Aug 2009
    12
    Its just chewing the teeth off the spur. Pinion looks good, no wobble to the spur. I'll try the slipper approach. Appreciate the help.
    65
    happened to me aswell, you have to be really careful because small stones can get in the teeth of the spur and since its nylon it strips those teeth, not the pinion.
    When you lose radio control at top speed, RUN!
    15,251
    I swear, some of these spurs are junk to start with.
    Ya can't polish fertilizer...
    Apr 2009
    351
    i stripped my first spur on my slash which is brushless. What I am seeing that is happening is that dirt is getting into the cover and getting stuck in the spur gear. This alone does not cause the spur to strip. What happens is over time the dirt that has gotten in the spur is actually chewing up the pinion gear. If you look at your pinion really close it looks as if its being grinded down. The pinion ends up getting really sharp and burred up badly due to the dirt. Eventually the spur will fail. Replace the Pinion and the spur at the same time.
    2008 Revo Platinum Edition.
    Indianapolis, IN
    1,040
    http://www.rpmrcproducts.com/product...ires/80525.htm if you are aligning it right this should fix your problems. It sealed by the driveshaft so nothing small can get in and eat your teeth. Some hobby shops carry it other wise I ordered mine online for 7 bucks shipped and haven't lost a spur in over a month and I run on gravel and loose dirt a lot.
    Dec 2008
    Gettin' Lucky In KY
    3,917
    Well there is 3 causes to strip a spur that I can think of right off the bat.
    1) Staying in the throttle too much while landing from a jump with a tight slipper setting.
    2) Incorrect Gear Mesh.
    3) Stock style motor screws loosening up allowing motor to move.
    If the culprit is the motor screws. I'd suggest getting the Lunsford Fatboys Long motor screws. Yes $8 for motor screws my be crazy but once you use them you'll never use another type of motor screw again.
    65
    Quote Originally Posted by RByers8252
    not all of it though. The titan has a built in fan which acts a vaccum and sucks in alot of dirt to the gears.
    Apr 2005
    the land of GO FAST
    1,512
    how many turns out is the slipper nut? do you do the two-foot slip range like the manual says to set it up?
    RC enthusiast!
    Apr 2009
    2SON AZ
    190
    Quote Originally Posted by rustlerbasher
    I snug tighten with the supplied wrench, then 1/2 turn back off. I did chew up a spur, but a pebble got in. Another tip is get a Losi pinion, 48 t pitch. It will make your slash whisper quiet. Just my .02
    Jammin' Nitro Truggy 1/8
    Slash 1/10
    Slash 1/16
    65
    Quote Originally Posted by Tanman11
    ya not to mention the losi pinions are made from a higher grade steel and are much better than the stock traxxas aluminum ones. I usually loosen mine about 1 turn off. It's been working well so far.
    Sep 2008
    2,121
    get 32p.................32p is a lot better than 48p (stock) cuz the teeth are way bigger so is dose not strip as easily but you can not run with a gear cover
    Race-bred SSC 4x4
    Durango DEX410
    Apr 2009
    2SON AZ
    190
    Quote Originally Posted by 1slash
    I don't agree with a 32 p being a lot better. Bigger teeth = sloppy teeth. Also if you take the time to set up everything correctly, you shouldn't (not won't) but shouldn't strip gears. The occasional pebble, or sand will still get in there and cause damage, but set up is key.
    Slash 1/10
    Slash 1/16
    Sep 2008
    2,121
    i know that, but people that have problems like this switch to 32p and then no problems ... but you say what you want to say
    Race-bred SSC 4x4
    Durango DEX410
    127
    I have ran 32p on 3s with no gear cover for nearly a month. The spur and pinion look brand new. I dont care what anybody says, the Traxxas spur gear has a serious design flaw. Most every other spur gear in the world is flat. Why Traxxas decided to go with the bell shaped spur is a mystery. I have bought numorous stock gears and set them on the table only to see that the thing was seriously warped.
    I have like 5 buddies that all run stock gearing on Slashes, and 100% of the time at least one of them strip their spurs during the bash session.
    I will never run 48p again on my Slash, setup means nothing when half the time the product is the problem.
    this is just my opinion after numerous attempts at try to dial in 3s with stock gearing.
    lol...I am at 20%
    115
    You might also check the motor bearing and be sure the shaft is not moving or have any slop to it. I have seen a few 550 motors loose the bearings and then with the slight movement chew up the spur gears. Just make sure the shaft does not have any play in it.
    Dec 2008
    Gettin' Lucky In KY
    3,917
    32P is stronger than 48P gears. But like said if 48P is setup correctly you shouldn't have a problem with them. I know I've never had any problems with 48P.
    Sep 2008
    2,121
    Quote Originally Posted by CarGuy7a
    me, i don't wast my time with 48p now cuz its just so fiddly
    Race-bred SSC 4x4
    Durango DEX410
    Indianapolis, IN
    1,040
    For starters to hacknslash. We are talking about the Titan motor. We are talking about the spur gear and pinion getting destroyed. The motor isn't magically sucking in pebbles and spitting them through the watertight shaft housing :-p and second for Slashnewb they may be right about your motor screws. If they are not tight enough your motor can budge and walah you have lost a spur gear also if you have made them too tigh in the past you may have stripped your motor holes and need bigger screws or a new motor. If you are positive your motor is mounted tight than the RPM gear cover should solve all of your problems. Also just something you should know already after every few runs (etc 5 or so) you want to check your motor to make sure it hasn't came loose sinse when bashing it will happen from time to time. Don't waste your time on a different pitch.
    Sep 2008
    2,121
    i fined the rpm gear cover dose not do a ton
    Race-bred SSC 4x4
    Durango DEX410
    127
    .... Don't waste your time on a different pitch.
    how is it wasting time if it works? I have yet to eat thru a 32p gear..with 48p I would have to change my gear after about 2-3 bash sessions...now I have been bashing 3s on 32p with the same spur for over a month..no problems...so who is wasting time? not me, thats for sure.
    its a well known FACT that it works, and works well-it is almost the exact same ratio and if your concerned about gear covers, well there is a way around that as well...dont try to deter somebody from trying something different unless you give them a good reason not too.
    lol...I am at 20%
    Apr 2009
    Cape Cod, MA
    61
    Make sure the motor adjuster screws( the one you adjust for the pinion) are super tight. I had the same problem and now i have them tight it is less of a problem.
    Lancaster California , Sand dunes next to the rattlesnake that almost bit me
    274
    I have not stripped a spur gear or pinion gear since switching to the 32 pitch setup. I agree that 48 pitch works well with the titan motor but when you go brushless the 48 pitch is not designed for that kind of power.The teeth are just to weak(small) the 32 pitch is perfect for the vxl brushless setup. The downside is -yeh you wont be able to use a gear cover anymore unless you put washers under it and tape around it to keep the dirt out. Mine is not covered and I have not had a problem with it for over a month now. RPM needs to design a gear cover that will fit over the 32 pitch gearing setup. It will solve alot of problems.........Just my 2cents.........Legend
    Me or the Rattlesnakes, One of us has to go !!!
    Feb 2009
    Sacramento
    1,861
    do any of you guy know that when you run a gear cover (stock or RPM) dirt gets in side NO MATTER WHAT! then while the dirt/sand sits in your gear cover and bounces around it has a blender affect on both spurs and pinions
    (^ that works for both 48p and 32p gears with a cover,BL w/lipo,and brushed)
    Apr 2009
    351
    So honestly it may be better to run without a cover no matter what pitch spur and pinion you run.
    Feb 2009
    Sacramento
    1,861
    and running with out a cover will be like trying to throw sand in a fan thats blowing at you.
    and it bounces off
    127
    when I ran with a cover I coated the inside of it with black gear grease, whenever dirt got inside the cover it would just stick to the grease.
    I would have to change this out after every 1-2 sessions, but if you do regular maintenance like your supposed to its no biggie.
    lol...I am at 20%
    May 2007
    In a van down by the river
    145
    Another suggestion would be to check how much play is in the top shaft that the slipper assembly bolts up to. I went through seven spur gears in a matter of a month, I tried everything, loosening the slipper, adjusting the mesh every way possible, and new pinions, the alignment was dead on. Finally I took the slipper apart and found out there was a ton of slop in the top gear/shaft, the bearing had gone bad. I replaced the bearing, and have not had a problem since.
    Jammin SCRT10 4x4
    1/16 VXL Slash
    Revo 3.3
    SC10
    Sep 2008
    Was there, now here.
    2,434
    32p FTW!! It even sounds nasty.
    RustyVXL, HPI RS4 Rally, RC18MT
    Mobius1 crashed!
    Apr 2009
    4901'19"N, 12248'26"W, Canada
    452
    32p makes you wonder why 48p setup even being used by traxxas, seriously, you just won't need another spur change until it is completely worn out
    3905,3708,7108
    5805,17/58,REM,VXL,1/8
    127
    ya it is weird...alot of people have problems with stripping gears...in fact a guy I bashed with today went thru 2 48p spurs. Brushless/lipos is too much for 48p.
    I keep telling em to switch pitches, I have been running 32 pitch for about a month with no gear cover and my spur/pinion look brand new.
    I dont know why people have a hard time accepting that his mod works, and works very well. Like I said before..I will never run 48p again in my slash..now if RPM can get on the boat and make a working gear cover than that will just be the icing on the cake.
    lol...I am at 20%
    Apr 2009
    452
    tell me about it, when I had the 48p i had to use my knife to pick the sand and stones that got trapped between the teeth every f'ing 10 minutes, rather stock cover, rpm cover, or no cover, stripped 3 spurs in 3 days regardless the perfect mesh that I did. After switching to 32p, ZERO maintenance for 300+ packs and counting, on the same spur. WHY 48p??? I got to agree with Stamjato though, I don't see the point of having a cover with the 32p. I run my Maxx without a gear cover since day one with zero problem also
    3905,3708,7108
    127
    ya I agree, you dont need a gear cover.....but most tracks require one for marshal safety. I am not a fan of rigging things with washers and stuff, so a proper fitting gear cover would be nice when needed.
    lol...I am at 20%
    Feb 2009
    Sacramento
    1,861
    if you set your mesh right and the motors tight you should not be striping spurs
    Sep 2008
    2,121
    is this how you put on the 32p gears. ignore the arrows. i had to put the pinion on back wards cuz it would not go on the other way cuz the shaft was not long enough i know i have the spur on the right way i just don't know about the pinon
    Race-bred SSC 4x4
    Durango DEX410
    127
    that is correct man, backwards pinion is the proper way to do it...have fun!
    lol...I am at 20%
    Sep 2008
    2,121
    ok thanks so much dude!!
    Race-bred SSC 4x4
    Durango DEX410
    Indianapolis, IN
    1,040
    I'm not saying 32p is a waste of time (exactly atleast) but for some of us we already have 20 bucks or so invested in pinions alone. I've ran the same spur gear 48p almost 2 months now. No I'm not brushless but my brother is and has just as much luck. If you put the gears on and tighten the motor right your good to go. Also even after bashing from mud to gravel for an hour straight my gear case was almost bone dry and had no rocks or pebbles in it. Nothing special done to it.
    Slash VXL
    Summit VXL
    they have to share for now
    Feb 2008
    sterling hts MICHIGAN!
    2,034
    I havent striped a 48p spur gear in a long time now, and Im going high 30s, in mph lol and I use no motor cover whatsoever!!!
    if you want me to i can break your truck for free!
