    Sep 2009
    4
    Jato alignment issue
    Hi there,
    I had an awful accident with my Jato and had to replace the part no. 5533 (Traxxas Rear Left & Right Suspension Arms) and part no. 5523 (Chassis Top Plate) and ever since I have a weird problem with steering alignment. I notice that whenever I push the throttle the car moves to right and when I release the throttle it moves back to normal.
    Any idea what could cause this problem? Is there any adjustment that I possibly ruined while replacing those two parts?
    Thanks
    Oct 2008
    Australia
    141
    Check your hexes
    A sure cure for seasickness is to sit under a tree
    Sep 2009
    4
    the hexes are fine....it looks like a differential problem. I noticed when the engine is off and the car off the ground and i rotate one of the rear tires the other one spins in the same direction! it should spin to the opposite direction.
    Any ideas?
    Jul 2009
    Texas
    175
    my tires spin in the same direction with 100k diff fluid, they aren't supposed to spin in opposite directions.
    Sep 2009
    4
    My friend's jato tires spins in the opposite direction and is working fine (the car is relatively new. So which one is right?
    Jul 2009
    Texas
    175
    I forgot an underline in my answer, they can spin both ways, it's fine. Your drivetrain is probably very smooth so the diff does not slip. Sounds like your toe or camber might be out of whack on either then front or rear wheels. Check those first.
