    Sep 2009
    Mandurah - Western australia
    211
    Jato ratio calculator
    if any jato owners out there are after a spurr/clutch bell/tire size calculator i've done a quick Excel calculator which gives spurr / clutch bell ratios , final drive ratios and effective ( including tyres) ratios which is all editable.
    If your interested PM me an email address and I'll send it over.
    or if someone knows how to host the .xls file that'd be even better.
    NOTE: this is suitable for jato only using Jato gearbox and diff ratois
    RC Turnbuckle Jr. Desert JATO's Avatar
    Aug 2007
    Riyadh, Saudi Arabia
    5,661
    is this calculator on a web site ? if yes, just link it here...
    i'm not sure about how can i host a accel files ( if it's the .xl's you meant )
    Sep 2009
    211
    Quote Originally Posted by Desert JATO
    found a free online .xls hosting service.... wait for the countdown then download .
    JATO-RATIO-CALCULATOR
    screen shot
    Please let me know what you guys think
    Oct 2008
    Australia
    141
    Just looking at your pic you posted, it looks as if there something wrong with the single speed calculation. The single speed ratio shouldn't be a lower ratio then the 2nd gear of the 2-speed box.
    A sure cure for seasickness is to sit under a tree
    Sep 2009
    211
    Quote Originally Posted by Buckshot
    Took a couple of hours just to find the single speed gear ratios but if your saying the single speed shouldn't be a lower ratio than 2nd gear could some one please let me know the single speed ratio or at least how many teeth pre drive and driven gears so I can correct this.
    The only info I found for the single speed was 20t/31t
    Oct 2008
    Australia
    141
    Here's the corrected Excel sheet hope you dont mind the changes I made, they were for my own ease of use. http://www.tempfiles.net/download/20...TOR-FIXED.html
    Sep 2009
    211
    No problems, thanks for the fix.
    I've also corrected the original version for single speed
    Didn't realize there were other spur / c/bell apart form the 54/56/58's. turns out there are 53/55/57's and also 17/21/23 c/bells
    Jul 2009
    88
    Exclamation Best Gear Ratio Calculator I've Found Yet!!!!!!
    Quote Originally Posted by kamipalms
    Awsome, Awsome, Awsome
    This is great, thank you guys!
    Keep Up The Good Work.
    Support The Dying Art Of Thinking For Yourself !
