Results 1 to 17 of 17
    Channel Islands, UK
    1,075
    ******* 20c have more punch than ***** 30c's
    Hey people,
    I ran my E-Revo earlier today and had a blast with it as usual
    I ran through firstly a set of ***** 5000mah 30c hardcase which performed well but then when they ran dry I put in my ******* 5000mah 20c batteries and the difference was incredible! They have a huge amount more power, the difference was hugely noticeable.
    I would definately recommend going ******* over *****, I'll only buy ******* from now on.
    Hope this helps people making battery choices.
    Cheers,
    Jonny
    Apr 2009
    12
    anyone else tried the ******* 20c ??? any other feedback?
    Registered User
    Apr 2009
    MN
    607
    i got ******* 30c
    May 2005
    44
    Quote Originally Posted by Double A
    i got ******* 30c
    Do you like them? What gearing are you running and how hot do they get? I need to order either the ******* or ********* 3S 5000's this weekend and am trying to make up my mind.
    Mar 2009
    104
    i run ******* 3s 5000mah 30c and it feels like I can use any gearing I want.
    Registered User
    Apr 2009
    MN
    607
    same as the guy above and they never really get hot charging or after running them always able to touch at anytime
    Jul 2007
    1,323
    I run the ******* 2s 5000mAh 20c packs in my ERBE geared 18/54 and I love them. I have 2 sets and they have been great. They barely get warm.
    I need R/Cers anonymous.
    Dec 2008
    STL. MO
    1,559
    how many runs are on the zippies. if they are new, they will take a lil while to wake up
    HB Ve8 w/ tekin (AWESOME)
    E-Slayer w/MMM
    SC10
    The Netherlands
    143
    I'm also running ******* 3S 5000mAh and they are great.
    Wanted to order another pair from *********, however the *******'s were not in stock, so I ordered 3S 5000mAh *****'s.
    As soon as they are here, I'll see which one is the better. But on 6S total, I don't think I'm really gonna see much difference...
    Sep 2009
    TJHSST, NO VA
    1,054
    i also have 3s 5000mah turnigies and i haven't ever changed the gearing and i works great i break something everytime but i cant seem to do a wheelie with it but i dont care really i did it when it was wet i would do it now because its dry but my tires went boom and flew higher than a house
    Dec 2008
    FW, Indiana
    943
    Quote Originally Posted by Brushless Moose
    Ive had 4 runs on mine and they arent woken up? Holy crap how much more power can these put out?!?!
    Are you an RC addict?
    Dec 2008
    STL. MO
    1,559
    I meant the zippies, not the *******s maybe that's why the zippies are slower if they havent woke up.
    E-Slayer w/MMM
    SC10
    Channel Islands, UK
    1,075
    They *****s only have 2 runs less than the *******s.
    The ******* batteries have lower internal resistance according to my charger compared to the *****s.
    The *******s have a 2c charge rate too which the ***** doesn't.
    The *******s take on around 5100mah in a charge, the *****s take around 4900 and the *****s last longer, indicating they are discharging at less amps.
    ******* batteries are higher quality and produce better power in my truck, FACT.
    Aug 2009
    283
    I have read on rcm somthing about the 20 c and the 30c batts are the same lipo just different sticker on the pack. Somebody tested them on a eagle tree and they came up almost identicle in amp output.
    Jun 2009
    The Rotten Apple
    874
    Quote Originally Posted by SuperGmaxx
    Yep almost all of the batteries I have load tested are way overrated.
    havnt failed I just found 1000 ways that wont work
    May 2005
    44
    I ordered a pair of the Tunrigy's. I am running a 1515/2D and it didn't take long to wear out one of my trakpower 2s 4900's. I figure for as cheap as they are it's worth a shot. If that doesn't pan out I'll go with some 3s flightpower packs that my LHS has. Way expensive though.
    May 2005
    44
    I got my pair of the ******* 35-45C batteries. I am running a 1515 2D/F in the revo. It's geared at 23/68 and I am running the big proline moab tires. Its WAY too fast. I'll have to put a GPS on it. Battery temps don't get above 98 and motor temp is about 175. I think with the stock rims and response tires the speed will be manageable but no way am I going to keep the front end down if I hammer the throttle. I have burned 2 clutches already (adjusted 1/8 turn from tight).
    I set the controller to cut off at 3.5V/cell and my charger puts back 5300mah. I wish I could have it cut off at 3.6-3.7. I'll have to check resting voltage when the cutoff trips next time. I don't want to discharge them too much.
    So far I have been very impressed for the price. We'll see how long they last.
