Results 1 to 17 of 17
    Apr 2006
    Australia
    900
    Brushed 4x4 Slash?
    Anyone know if a Brushed version would be coming out?
    Dec 2008
    STL. MO
    1,559
    probably not why?
    HB Ve8 w/ tekin (AWESOME)
    E-Slayer w/MMM
    SC10
    Apr 2006
    Australia
    900
    They did a brushed and brushless version of the 1/16 and most other vehicles have a brush or brushless system in it.
    Jun 2009
    SE PA
    644
    If you want brushed i have a XL-5 system ill trade for the VXL. Ill ene throw in a brand new motor.
    Jun 2009
    Ontario, Canada
    390
    Or even better just spend the $15 or so on eBay for a new 2wd slash motor and run that with the VXL. I'm thinking of doing that so when I race with my friends and their stock 2wd slashes we should still be even on speed but I'll still have an advantage of the 4wd.
    785
    Why would you want a brushed one...
    I could see if the brushless wasn't out and they made a brushed first...
    Just set your VXL system to training mode when racing your friends...
    That way your only at 50% power. Still probably more then they'll have stock but will give them more of a chance. Or when you start the race give them a head start and try to catch up. Or start at the same time and give them a two or three car lead at the starting line.
    Slash 4X4 PLATINUM EDITION, Revo 3.3 Crawler
    Jun 2009
    Ontario, Canada
    390
    I don't want a brushed one, but just what I plan on doing as I have a few of the 2wd slash motors laying around. Besides it's just as easy to switch out a motor as it is to play with the ESC and change it back and forth from training mode to normal mode. Either that or I'll see if I can convince them to either VXL their slashes or buy the 4x4 which is probably what will happen when they see mine run on our cottage track.
    Sep 2008
    Edmonton, Alberta, Canada
    1,548
    Quote Originally Posted by revolt0
    you do know that the VXL esc can run brushed motors, right? it would probably be easier to switch back and forth with training mode instead of the motors imo.
    Jun 2009
    Ontario, Canada
    390
    Well yeah, hence the reason I'm thinking about using a 2wd slash brushed motor, I said nothing about changing the ESC... Switching either is about the same except if you are out at the field and don't have your programming instructions, then swapping motors is even easier.
    Sep 2008
    1,548
    programming is so easy you could teach a fish how.
    if your a newb, twist-tie the instruction card to your transmitter. thats what i did till i learned how to do it by myself
    Jun 2009
    Ontario, Canada
    390
    I know programming is easy but I have so many other important things to worry about like programming my 4pk or dx3r that remembering the ESC programming isn't important that's why I'd rather set it and forget it and remove a couple of screws and replace the motor. As for being a newb I'm far from it.
    Jul 2002
    Atlanta, GA
    907
    People want brushed because it would cost less.
    Jul 2009
    1,055
    i would imagine that it would be preeeetttttyyyy slow, i mean, can u imagine that thing with a titan? 20mph on 6cell nimh yay!
    Wide Rustler | "Bulldog" Backslash 4x4
    Apr 2006
    Australia
    900
    Quote Originally Posted by Bmr4life
    Yes, that was the reason.
    May 2006
    184
    just save a little longer and get the bl you'll be happier in the long run..besides if you wanna slow it down limit the throttle epa i would assume 30-40% would achieve a good pace without being too fast
    TRX Slash
    TRX Homemade SCT
    TRX Mid-Engine/Slash
    Feb 2008
    822
    You can remember how to program 2 radios but not your esc... Wow I don't feel so wierd anymore. lol I'm kidding. You should try using the twist tie for your instructions.
    Aug 2008
    104
    Quote Originally Posted by Thunderbruiser
    They want a brushed version because there going to put there own BL system of choice in it. And it would be alot cheaper. Not because of the power
