Results 1 to 21 of 21
    Jan 2010
    584
    Front rockers in the rear?
    What exactly does this do? Any downsides?
    Thanks!
    Jan 2010
    Alabama
    858
    I would like to know as well. Anyone have a side by side pic of the two?
    Aug 2007
    So Cal
    21,507
    If memory serves me correctly it will raise the ride height of the rear of the MERV. This will keep the truck from bottoming out but also raise the COG
    BlindMan Racing
    Rusty - MERV - Pede 4x4-Alias
    SPC Lipo Power
    Mar 2009
    Escondido
    324
    For me the ride height is the same,the reason I did it was to lessen the e-revo squat under acceleration.It drives better than ever
    Apr 2007
    2,502
    yes i did this on my 1/10 revo and it took away almost all of the sag in the rear under a good amount of acceleration. it doesnt just like scrape under acceleration, or even almost scrape. it holds the back end up quite a bit and helps it not bottom out as often. it does make the rear suspension a bit stiffer than the front so i just switched the rear springs to the front and front to the rear and now it is very even. my ride hight still gets as low as i would ever want it..
    Later!
    Jan 2010
    584
    The springs should be the same front-and-rear, aren't they?
    Registered User
    Apr 2009
    MN
    607
    on the mini i think they are but i did the switch on the mini it seems to help alot lookin for rockers fro the big one now
    Apr 2007
    2,502
    i know i was just saying that on my 1/10 nitro thats what i did...
    Later
    Jan 2010
    Alabama
    858
    Quote Originally Posted by BAC5.2
    The springs stock are the same. But people run different springs based on preference.
    To give some insight into what is happening when the rockers are changed you have to understand the concept of motion ratio.
    All suspensions have some motion ratio due to the kinematic differences in the mechanism that actuates the damper.
    In our ERBE/MERBE/mini slash case we have a PRD configuration (Pushrod Rocker Damper) setup
    The geometry of the setup determines many things about the suspension. By changing the rocker you can change a couple of main things. But the biggest change is to the motion ratio of the suspension.
    You can calculate the motion ratio of a suspension system my measuring the amount of wheel movement to the amount of damper movement. By changing rockers on our trucks we effectively change the motion ratio. Changing the motion ratio changes the wheel rate so it would appear that we now have a stiffer spring on the rear, when in fact the spring is the same.
    Since the motion ratio effects the relationship of wheel movement (up & down) to damper movement it would make sense that the motion ratio also effects the relationship of wheel compression velocity to damper compression velocity.
    This is important because damping is velocity sensitive. More speed=more force.
    This is because fluid resistance increases at the square of velocity. That means that when changing the rockers you should also change the damping (shock oil weight change or piston configuration change)
    If anyone has more questions let me know. Suspension just happens to be my day job.
    Dec 2009
    Washington
    63
    My brother put front rockers in the back. It lifted the back way up an made it look funny. It rolled to easy because the center of gravity was higher.
    E-Revo BE, E-Revo VXL, Rustler VXL, Jato 3.3.
    Apr 2007
    2,502
    You just gotta drop the rear preload, raise the front preload to match what your selection of the rear preload and it shouldn't roll near as much ..
    Aug 2007
    So Cal
    21,507
    Quote Originally Posted by revo_maniack
    So what is the point of putting front rockers on the rear if you are just going to readjust the suspension to make the ride height the same as it was before?
    BlindMan Racing
    SPC Lipo Power
    Jul 2009
    Quebec
    374
    I run with the opposite mod lately. I installed rear rockers up front (with an extra bearing underneath).
    Since I mounted huge tires (diameter of 4.5") to run in the snow, my ride height was too high. I could not bottom out the front. Therefore on full shock compression all the remaining force was being transfer to the shock mount. I am sure something would have break sooner or later... So I found a way out by doing this reversed mod!
    Don't forget to give credit to Zrau17 for the original idea. Ref Thread : Bahers Read!!!
    What have you learned today?
    Jan 2010
    54
    bumping this up. did this today:
    switched front rockers with rear rockers and adjusted suspension. There is wayy more travel in the rear, and i no longer have the saggy rear problem i was having before.
    I also like the way there isnt as much movement upfront.
    for me it HANDLES WAY BETTER.
    Jun 2020
    Texas
    179
    Bumping this thread up to this decade...
    Does anyone use this mod or one similar? What results have you seen and how did you have to adjust springs?
    RC Champion zedorda's Avatar
    Sep 2015
    S.E. Michigan
    1,411
    After reading through the thread there is not much to add. Post 9 pretty much explains what you should expect. I can't say this is a mod anyone would do for long plus it depends on which model you have since not all of them have the same rocker setup.
    I bought the long travel rocker set for my revo and it made the suspension super soft with more travel. Increased traction rolling and made the chassis slap more. The longer the rocker the thicker the shock oil needs to be. I hated how it drove and switched back after 2 packs.
    https://www.amazon.com/Traxxas-Rocke.../dp/B0049MCK76
    Jun 2020
    Texas
    179
    Thanks - yeah I am not looking for additional height per say because that would be disastrous like you found out in regards to control. Long travel rockers won't do, but having the progressive rockers from the front on the rear to allow more droop when in the air might be useful. I would still want to adjust it all so that the control arms are mostly level when at rest for best control in turns. Just curious what other people found when trying it out.
    Sep 2015
    S.E. Michigan
    1,411
    The Merv comes stock with the long travel rocker on the front. So all I actually switched were the rears. The Slash comes with short travel front and back while the Summit has the long travel front and back.
    Jun 2020
    Texas
    179
    The exploded map says it comes stock with progressive rockers in front and back (Part# 7158). The front are longer than the rear, but do not appear to be the same as the actual long travel rockers (Part#7156), which come standard on the 1/16 Summit. Comparing the pics of each I see the subtle differences.
    So it sounds like you put the progressive front rockers on the rear and found that it made the suspension supersoft and increase rolling. What springs did you use and did you reduce the preload to lower the truck back down to normal heights?
    Sep 2015
    S.E. Michigan
    1,411
    Quote Originally Posted by halygon View Post
    I only did a simply look over them but they seemed the same. PRS style suspensions are always progressive by design so not sure what could be different between the two but I don't doubt I lack the knowledge to identify the difference that would make them progressive or not. As for springs I run the purple in the back and blue in the front.
    Left is rear, right is front. I only used the rears. But I think I see the difference now. The shock mounting hole and the pivot are closer in the long travel rockers. I am guessing that affects the progressive nature to some degree.
    Dec 2014
    Adirondacks
    2,115
    The Merv comes stock with the long travel rocker on the front...
    The exploded map says it comes stock with progressive rockers in front and back (Part# 7158)...
    My mini Erevo came with progressive 2 rockers on the front and the rear.
    They are different than the long travel rockers. The distance from the pivot point (rocker post) to the shock mount (shock end) point is closer together on the LT rockers and farther apart on the P2 rockers.
    The pushrod end to rocker post is longer on the LT rockers and shorter on the P2 rockers.
