Page 14 of 14 FirstFirst ... 4121314
Results 521 to 552 of 552
  1. #521
    Apr 2013
    333
    Can someone explain if Steve's explanation of using oil in the rear diff instead of grease is in the housing or the diff centre itself????
    Keep on Bashing and you will keep on Trashing
  2. #522
    MS
    90
    The diff center, the plastic cup that is screwed to the ring gear. The diff housing is not sealed and will not hold fluid.
  3. #523
    Apr 2013
    333
    Thanks turnleft, I'm going to work on diff tuning this weekend, with my lack of ability at the trigger I find I get to much wheel spin at the rears in loose conditions, centre diff is in.
  4. #524
    MS
    90
    I have 10000 in my rear diff and it works great for loose conditions.
  5. #525
    friendswood texas
    1,733
    Quote Originally Posted by Scubbastevebmxr View Post
    What setup tools do you use Steve (or others)? I've been looking at hudy's off road setup kit and integy's setup kit. Any suggestions on total offroad setup systems?
    Just a basher here but I run steve's set up. I use toe and camber guage from RPM and they work great.
  6. #526
    Jul 2005
    elkton,maryland
    24
    why do you use thick weight shock oil in the front and rear shocks 55wt and 60wt seems very thick for offroad racing please help max
  7. #527
    Apr 2013
    333
    Quote Originally Posted by maxxpower78 View Post
    To help absorb impact on the up ramp of a jump and to also help absorb landing, as you try to land front axle first on the down ramp of a jump. Softer in the rear to allow the rear end to squat under power to give more traction to the rear wheels.
  8. #528
    Jul 2013
    4
    Hi,
    Can anyone help me get a setup for my race slash 4x4.
    Its running the STRC LCG chassis and the proline protrac kit. My track is a fairly bumpy outdoors track favoring the 8 scale nitro buggies. I have Texin RX8/Pro4 4600 and Savox 1258tg servo. I have the 13mm GTR shocks whith AE springs. Its really fast but tries to swap ends all too easily even whilst powering on the straight. It jumps great though but just not stable.
    My current setup is pretty much Sleydan's as far as oils and arm mounting points go, but running 3deg toe in and 2deg neg camber at rear. Shocks mounted middle on tower and full outer at rear. At front I got 1 deg toe in and 1 deg neg camber and got my shocks middle on tower and 2nd from outside on arms. I am running Sleydan's sway bars.
    My other truck is a race prepped TLR Ten SCTE 2.0 and that thing is just way faster and more stable everywhere, but it jumps real bad.
    Please help!!
  9. #529
    RC Turnbuckle Jr. mwe-maxxowner's Avatar
    Feb 2004
    pageland, sc(south of monroe)
    5,697
    I have the gtr shocks on my truck. What springs should I look into running on these?
    460, straightpipes, buried throttle, nuff said :D
  10. #530
    Oct 2013
    Maryland, USA
    171
    Hi Guys,
    I have slash 4x4 and I am confused about this it has front differential oil, rear differential oil and center differential oil where did you put center differential oil? Any ideas....
    Front end:
    - outer steering link: front hole (plastic knuckles)
    - shock springs: Slash 2wd fronts or Rustler fronts work well
    - camber link: outer/ lower & inner/ upper
    - diff: 10K to 15K
    Rear end:
    - sway bar: black
    - diff: 5K to 7K
    - install center diff (50K to 100K)
  11. #531
    Feb 2004
    5,697
    Do you have a center diff for your truck? Or only a slipper? The center diff has a diff case you can open up just like the front and rear diffs that you can put oil in.
  12. #532
    Dec 2013
    47
    Hi Guys,
    we have a race and bashing track in a local wood. Do have any recommendations what is the best setuo for my Conditions ? The wood soil is anywhere between hardpacked and loose (more loose than hardpacked) but not loamy and most of the time dry. The most important thing for me is acceleration and tracking stability, everthing else does not matter.
    Thanks for your help
  13. #533
    Mar 2014
    Oak Ridge, TN
    84
    I have read this entire thread and onlt one unanswered mention of GTR shocks from the current slash ultimate .
    Is there a listing of all traxxas shocks, springs and their compatability, and sizes ?
    Their shock names are confusing.
    Slash Ultimate 4x4
    STAY AWAY FROM BIZARRE HOBBIES
  14. #534
    Jul 2014
    Selb, Germany
    15
    Hi,
    what is a good setup for the street? I also drive a litte bit on gravel but mainly on street.
    Thanks
  15. #535
    Jul 2014
    Selb, Germany
    15
    Quote Originally Posted by aggie rustler View Post
    via RCShortcourse.com from sgrid - thanks mp3ranger
    Front end:
    - diff: 10K to 15K
    Rear end:
    - sway bar: black
    - diff: 5K to 7K
    Which unit do you mean? CPS/CST or WT?
  16. #536
    Aug 2014
    Poland
    84
    The diff oils is always in cps.
  17. #537
    Aug 2014
    My brain is spinning. Is there anywhere I can find a glossary and some good fundamentals? Thanks
  18. #538
    Jul 2014
    68
    At the shock positions, does he then mean #2 closest to the tire or closest to the chassis?
  19. #539
    RC Qualifier traxxasvxlbasher's Avatar
    May 2013
    Alicante, Spain
    780
    Quote Originally Posted by Offroader13 View Post
    i think is from the tire... the one chassis will give it really really high centre gravity
    | Slash 4x4 | Stampede 4x4 | E-Revo BL | RPM |
  20. #540
    Feb 2015
    Quote Originally Posted by traxxasvxlbasher View Post
    #5 is the one closest to the tire. #3 is the first hole closest to the chassis in the group of three bunched close together. The very first hole closest to the chassis isn't counted. Its for the the sway bar.
  21. #541
    Feb 2015
    Quote Originally Posted by tobiasGERMANY View Post
    The unit is cSt.
    10K cSt is around 770 wt.
  22. #542
    Jan 2015
    76
    Question Help needed!
    From Steve Slayden on sgrid forum
    The stock AND the Platinum Slash 4x4 trucks are both setup out of the
    box geared toward super high bite surfaces like parking lots, asphalt
    and stuff like that. That is why there is a level of push in the
    chassis and the stiff front end. Since most of the people buying them
    will be driving them on all sorts of random terrain and a lot of
    streets and parking lots, this makes sense.
    However, for the track racers out there, know that with a few changes
    you can have it dialed on the track. The entire chassis package is an
    awesome machine and is very capable of being fast. There's a ton of
    steering and corner speed in this truck with the right adjustments.
    Here's a few initial changes I'd recommend before throwing it down on
    the track for the first time. I'll post the rest of the setup
    afterward.
    Front end:
    - diff: 10K to 15K
    Rear end:
    - sway bar: black
    - diff: 5K to 7K
    Just doing these things alone will make the truck rotate nicely and
    provide controllable on-power steering exiting corners.
    I'll post my complete setup below.
    Be warned it may be long, but worth the read. I'll explain why on some
    of it. This truck is SICK when setup
    SLASH 4x4 setup: FRONT END
    - Toe: 1.5 (out), set at ride height with a slight amount of bump
    steer (bumpout). It seems to like a little bit of bumpsteer.
    - Static Camber: -2.0, set at ride height and measure each wheel
    independently with the wheel pointing straight forward.
    - Camber Link: inner: #1 & outer: lower, This corrects the camber rise
    to maintain a levelk of negatice camber when fully extended. It makes
    the font end (steering & control) more consistent & predictable
    throughout the suspension range. Use the #2 position for even MORE
    steering.
    - Shock Position: Upper: mid Lower: #2
    - Shock Length: 95mm, Increase the length by threading the rod end out
    to expose a couple of threads. Increase in down travel improves
    steering and helps settle the front end during landings.
    - Shock springs: Slash 2wd fronts or Rustler RED fronts. Should be the
    same as the newer white fronts on Rustler. These springs are softer
    than the stockers and feel pretty good. The Rustler springs are a
    linear rate and feel a bit smoother.
    - Shock oil/ pistons: 60wt/ 2-hole, This is good for 60F to 80F
    - Ride Height: Approx 27mm (shafts slightly below level), This will
    also be affected by tire dia. My setup is with Pro-Line SC Calibers
    and measured from surface to the skid just below the front of the
    inner hinge pin.
    - Sway Bar: Black (9mm in front of hollow ball)
    - Diff: 10K, mixing to get a 15K feel is also useable larger tracks
    with bite.
    - Bumpsteer: Flat: up
    Front end note: If using plastic steering knuckles, use the front hole
    for more steering. This will be the same as the Platinum with the
    aluminum accessory knuckles.
    The plastic knuckles are acually nice to have the second (rear)
    adjustment. This hole is good on large high bite tracks to keep turn
    in smooth and less aggressive.
    SLASH 4x4 setup: REAR END
    - Toe: 4.0 (blue carriers as marked), The 2.5's are good on small
    tight tracks and/ or high bite smooth tracks.
    - Static Camber: -3.0, set at ride height.
    - Camber Link: inner: #3 & outer: fixed on blue carriers and #3 on Pro-
    Line rear carriers. Use the #5 hole on the inner on small high bite
    tracks. It improves chassis rotation.
    - Hinge Pin Location: Lower, Try the upper location on really rough
    tracks. Reset ride height when changing this adjustment.
    - Shock Position: Upper: mid Lower: #3
    - Shock Length: 110mm, Increase the length by threading the rod end
    out to expose a couple of threads. Increase in down travel improves
    steering and helps the chassis settle during landings. Very handy on
    those tracks that don't provide adequate landing jumps.
    - Shocks Springs: T-Maxx White Progressives. These springs offer a
    firmer feel and are longer and require less preload, which allows them
    to work within a happy range.
    - Shock oil/ pistons: 55wt/ 2-hole, This is good for 60F to 80F
    - Ride Height: Approx 30mm (shafts slightly above level), This will
    and measured from surface to the bott the skid just below the rear of
    the inner hinge pin. Lower this setting to level with the front on
    high speed smooth tracks.
    - Sway Bar: Black (flush with hollow ball), switch to silver bar on
    dusty loose tracks.
    - Diff: 7K, Try 5K on really tight tracks
    SLASH 4x4 setup: The REST
    Wheels: Pro-Line SC One Piece (Slash 2wd rear offset) all the way
    arond
    Inserts: Pro-Line SC Blue
    Tires: Pro-Line SC Calibers, Bowties & Switches, Calibers have been
    good on most everything and consistent between bite and loose. Bowties
    favor loose and offer better forward bite vs. site bite. Good for
    chassis rotation and acceleration. The Switches are good on really
    hite tracks and abrasive surfaces. M3 is good in colder weather and
    also in dusty situations. M2 works well in warmer temps and on
    abrasive cleam surfaces.
    Motor: TRX Velineon (with TRX heatsink #1522)
    Battery: Max Amps 2S 8000
    Battery Location: rear
    ESC: TRX Velineon VXL-3s (with cooling fan)
    Gearing: Pinion: 14t/ Spur: 54t, use 13t pinion on tight tracks and
    15t on larger tracks. Larger pinions also add improves control of the
    truck in the air. Something to think about on jumps that buck the rear
    or high speed jumps that need a little extra to keep the front level.
    Center Diff: 100K, Try lighter mixes of 50K and 100K to get softer
    acceleration and better turn in.
    TX: Spektrum DX3R
    RX: Spektrum SR 3100
    Servo: Ace 1015
    Body: Pro-Line SC Hardcore
    Weight: My scale is broke, so with the battery, servo, heatsink, fan,
    wheels/ tires and such added into the mix, then that is what is
    weighs... LOL!!!
    I'll get it on a scale soon. I'm also going to be playing with weight
    placement and bias in the coming weeks. Keep in mind that lighter
    weight (smaller capacity) packs and/ or changes to the motor system
    and things like that will affect ride height and spring rate needs.
    Ok I have a question. I want some new shock springs for my traxxas slash 4x4 it weighs about 6.5 lb and the shocks are connected to the second highest spot on the suspension arm. I want some shocks that are good for jumps and don't let me chassis smack the ground every time. And some with a quick recoil any suggestions?
  23. #543
    Jun 2015
    5
    Can anyone help, I am new to all this, I have the slash 4x4/ultimate and I'm trying to figure out how to have the t lock switch and the shift switch control my fans. Right now as soon as I power up the car they come on so my transmitter does nothing
  24. #544
    Jul 2015
    29
    Would that be the same set up for slash ultimate 4x4 LCG? I'm very new to all this. I'll just be bashing around in the back yard on dirt.
  25. #545
    87
    Quote Originally Posted by Infinite10rc View Post
    Sound like the variable rate damping kit may be for you.
    Stampede 2wd VXL & Slash 2wd VXL
  26. #546
    Jul 2017
    17
    Can I ask someone this please lol. I am looking to get a 2400kv motor and esc for my slash 4x4 but I really can't spend 100 or 200 bucks on the castle ones. I see a bunch of cheap 2400kv motors and cheap esc but what is the difference? Are all 2400kv 4 pole motors the same or are thare different ones that say the same thing. I'm so confused. New to this and thare are tons of motor options and not sure what to get that is cheap enough and that I can race without overheating. Please help.
  27. #547
    RC Qualifier Amistry20's Avatar
    May 2017
    300
    Usually, you get what you pay for
    You will definatly get what you pay for with good brands like castle creations, hobbywing, tekin and others
    The more expencive ones, like the castle ones have higher quality magnets and last much, much , much longer than cheap ones
    Some dirt cheap ones that are like under 30 bucks will not give you anywhere near the same performance as a 150+ dollar one
  28. #548
    RC Qualifier broitsseth's Avatar
    Feb 2017
    wherever i decide to be
    433
    Quote Originally Posted by Erus00 View Post
    ive used it before just to see what would happen it handled HORRIBLE and had so much body roll
    cool ain't cheap -Dan Dreger
  29. #549
    Feb 2018
    Washington
    201
    So I just received a Slash Ultimate LCG 4x4 as a gift from the wife. Her dad will let me drive his from time to time, its a standerd Slash 4x4 all aftermarket part but most of the time I’m stuck with the stampede. So I’m pretty excited. The old already gave me a full set of RPM A arms A Traxxas Charger and a 3s 25c 5000 Traxxas battery and a dust cover. I have a few question. 1.how do I get more height out of my truck stock 2. Can I run 2.8 tires stock 3. Recommend upgrades 4. Any other pointers would be amazing
  30. #550
    Jan 2018
    Dallas, Texas
    181
    Hey, Slay. I'm kind of new to these forums and have wondered what tires would be good for a track like Indy RC World 2.0 in Garland Texas. I'm assuming you've been there because your location says Dallas. Any feedback is appreciated.
    TRX-4, Sl4sh (Race), Sla2h LCG, Sla2h, SCX10 II
  31. #551
    Feb 2018
    5
    When steve says shafts slightly below level on the ride height is he talking about higher at the diff or higher at the hub
  32. #552
    Apr 2018
    Victorville, CA
    Would this setup work well for a clay track?
    afterward.
    Front end:
    - diff: 10K to 15K
    Rear end:
    - sway bar: black
    - diff: 5K to 7K
    steering.
    inner hinge pin.
    with bite.
    dusty loose tracks.
    around
    TX: Spektrum DX3R
    Servo: Ace 1015
    weighs... LOL!!!
