just ran some 1550 3s in parallelwith speed pinion on.
This thing moves out!
Still have stock tires on it and gonna have to reglue the fronts it looks like . They didint come all the way off but a little on each side let go from the wheel.
its about 55 degrees here and had the stock body on it with a heatsink/fan for motor and the motor was 140 degrees and the ESC was 130 degrees.
Now for a question.
I have 30/50/30 in the Diffs and the front baloons pretty good.
What weight should I change and where at.
Will I totally lose wheelies, cause right now its pretty good i can wheelie when i want off the start or ease in and not wheelie. I like it liek this but I dont want to totally lose it.
Here is a pic.
Parts:
Dyed Chassis, Delrin Wheelie bar with Traxxas wheels, Delrin Rockers, GPM Shocks, GPM Pushrods and Toe Links, HR motor mount, STRC tranny mount, The Toyz Fan/heatsink, KO Propo 3101 Steering Servo, Aluminum Shock towers, Aluminum Steering componets, Traxxas CVDs, Integy Drive Shafts, and full bearings.
The silver GPM shocks look nice when everything else is black. I normally don't care for them, looks wise anyway.
Going thicker in the center diff should help with it unloading to the front wheels,.
I like to go thicker on the front and rear diffs too but thats just me
Personally, I would try the traxxas 100k diff oil on the center diff and use the 50k front and rear.
50/100/50 wont be the same handeling as 30/50/30?
Not sure how to phrase that question.
seems like it would act the same just with higher wt diff fluid in it.
But I dont know or else I wouldnt be asking these questions LOL.
It will change it due to the fact that since they are all thicker power will be more evenly distributed for the center diff and then the front and rear diffs will tend not to unload on corners so it won't turn as sharply but that is a better setup for off road from my expieriance but also you gotta fuss with it to suit you
My car learned how to fly then forgot the landing
Yeah right now the fronts ballon alot, i can live with how the rear is reacting.
Putting the 100k oil in the center diff will reduce the ballooning of the front tires while sending more power to the rears.Originally Posted by Blk95Cobra
I run 50/100/50 and love it!
I can still pull flips and wheelies but only when I want to. 100k center is the way to go for my driving style.
All advise is correct. Think of it this way, the center diff determines where the power will go. The thinner the oil in the center diff, the more power will be transferred to the wheels with the least traction. Accelerating, the front lifts a little so has the least traction so the center diff sends more power there. The thicker the oil, the more the diff leaves at the rear wheels. So, by adjusting the center diff oil weight, will determine how much wheelie you get.
The front and rear diff oil more determines how the revo will turn and how much power goes to each wheel on it's own axle.
Dennis
How would say 30/100/30 be compared to 50/100/50?
The center diff would work the same. In the case of the 30/100/30 the revo would turn easier and maybe go straighter under power, but if one of the wheels were off the ground, the other one on the same axle would pull less.
