my e maxx needs a new body but i need to know will the body holes line up with the body posts if i switch from the stock chassis to a FLM chassis
also how well are the stock battery hold downs on the FLM chassis do they hold good cause everyone i see with this chassis has diffrent battery hold downs and i would like to use the stock ones but not if my lipos are going to fly out LOL
thanks
if your not breaking anything get more air
yes it lines up. alot of people use different straps because with the FLM straps the batteries tend to move in head on collisions. I havent had any problems with em but I run usually at the skateparks where there isnt much to have a head on collision with.
Piercings can and will get caught in antenna tubes
Actually the holes will be slightly off cause the chassis is a few millameters longer.
BLEmaxx-3905
Fam. last words-Hey yall watch this!
i hold my ***** lipo like that
and here with my hard case lipo
and its work for me
the old body 3096 will need to drill new holes. i dont have the 3095 but I used their body and its direct fit
the one on the right with new emaxx 3095 body (direct fit with FLM chassis) and on the left has revo 3.3 body (come without holes so i drill the holes to fit FLM chassis)
MMM 2x3s medusa 70-2300 | MMM 2sx3s 1515 1y
The holes should line up fine, the FLM Chassis is a bit longer but I have swapped around the bodies from my stock to the FLM and there are fine.
I lot of people on here use Battery trays, I think it s the best way to go, it not only give more protection to the batteries but it also keeps them in place when you crash.
KD 700-HO 3905 - FLM E-Maxx MMM - ERBE - Slash 4x4
ok so i can go ahead and get a new body
are the novak battery boxs good will they fit a 8000mah 7.4 lipo or a 6 cell nimh side by side
here they are
http://www.shopatron.com/products/pr...er=S5050/135.0
Not sure about the battery trays. I have 2S 5000 Mah Hard Case and they'd fit, but I dont know if 8000 Mah are longer?? My Batts are about 136mm in Lenght. Do you have the batteries already?? If so then just measure them, the tray dimensions are there.
my lipos are 140mm long and 45mm wide
do you know the link to the new era battery trays casue i can't find them on there site
No sorry I dont. I got mine on Ebay, but RC Monster does good Battery Trays and you can even give him deminsions and he'll make it to your spec.
I used these trays with SPC 8000mAh 2s packs (p8) and GP 3300mAh stick packs (p5) : http://monster.traxxas.com/showthread.php?t=419028 (all the mods I made to mount these trays are explained).Originally Posted by scotthw
Note: it seems that the New Era Models battery trays are discontinued...
ok thanks popoxx
hey also i know traxxas e maxxs rear CVD won't fit i was told that the front ones will work do you think that the rear e revo CVD would work
thank
im not quite sure if that will fit, never tried, but the chassis kit does come with new front and rear center cvd's.
