Results 1 to 8 of 8
Thread: Gearing for mmm
    Jan 2010
    Albany,OR
    261
    Gearing for mmm
    Will i be fine with just staying with stock gear with the mamba monster 2200 with 2s 5000 mah 20c lipo?
    Stock Slash 4x4
    Summit MMM
    Aug 2009
    Cincinnati, OH
    20
    That's what I've been running on mine. The high gear is plenty fast for me and the low gear is still great for crawling.
    Slash VXL, EMBE, Summit MMM, Stampede EZrun
    Jan 2010
    Albany,OR
    261
    sweet all i needed to know thanks.
    Stock Slash 4x4
    Summit MMM
    Nov 2009
    74
    make sure your slipper is as tight as you can get it, i made the mistake of not have'n it tight enough and melted my spur gear.
    Mar 2009
    984
    Yeah stock will work fine, although you can go up to an 18-tooth pinion without any issues also (18/68 is what I run on mine).
    Jan 2010
    Albany,OR
    261
    the mmm comes with a 18 pinion so should i just stick with that then?
    Stock Slash 4x4
    Summit MMM
    Mar 2009
    984
    No get the RRP 18T pinion. The aluminum one that comes with the MMM is garbage (too soft, wears out almost immediately, and is noisy).
    http://www3.towerhobbies.com/cgi-bin...8718&search=Go
    Jan 2010
    28
    if you tighten slipper all way get your check book ready.
