Results 1 to 2 of 2
Thread: Knocking noise
    Nov 2009
    74
    Knocking noise
    Driving my slash normally nothing crazy, and i start hearing a knocking sound narrowed it down to the spur gear so pulled off the cover and and there were two tiny ball bearings embedded in the grooves in 2 spots, so i pried them out covered back up drove some more and within minutes the noise again so repeated and again there was another bearing in a groove apparently something has busted ...has this happened to anyone else and can anyone tell me where to begin trying to fix this thanks
    Jan 2010
    463
    bearing in front of the spur on slipper or bearing in rear diff housing. Dont run it till you check all bearings including the motor.
    good luck
