Results 1 to 17 of 17
    Jan 2010
    Southern Oceania: AU MY SG
    272
    TRA6840 GoPro camera mount
    Anyone seen any details of TRA6840 yet?
    Wondering where & how the GoPro is mounted on the car
    Los Angeles
    355
    I've been curious about the same thing. I'll probably just fabricate my own mount if it doesn't come out soon. I've already got the camera for my real car.
    Jan 2010
    272
    same!
    hoping that the factory design will be something that will hold the cam without
    any screwclamps... otherwise Hero starts "nodding" down after every bump
    can't every get it tight enough (yes even with a screwdriver haha)
    as the plastic-2-plastic in the clamp doesn't make enough friction
    Jun 2006
    Seacoast, NH
    186
    scuff the mounts up a little with some sandpaper. Worked for me! No more nodding down, or up, after that.
    Speaking of mounts, has anyone made up their own yet? I took the mount that the GoPro HD came mounted on in the package and cut it to fit the front of the chassis right behind the front shock tower and used the screw holes for the sway bar to hold it in. With the lower clip on the camera case, the camera power button rests nicely on the shock tower preventing the camera from nodding down also. I'll try to get some pics up later.
    Here's a quick lip of the mounts POV
    http://www.youtube.com/watch?v=6s9QDkjcE3o
    Jan 2010
    272
    how's the HD going, did you have a Std Def version before that?
    Tempted at getting an HD as i hear its Vision Field is narrower than the
    170deg Wide... which imho looks unnaturally too fisheye wide.
    Something 130-150deg would be just nice.
    I like having the fenders in view to give perspective.
    my last Slash mounting:-
    it might look like its just glued to the top of shell, but that shell's had
    a heap of aluminium framework stuck underneath from nose to tail
    to support the camera without bouncing
    Jan 2010
    272
    car's view:-
    Feb 2010
    Michigan
    174
    I just made my own mounting plate: http://monster.traxxas.com/showthread.php?t=509250
    It broke due to a hard crash, so I think a similar mounting plate made out of aluminum would be ideal.
    As for the viewing angle, the GoPro HD still has the 170* wide angle lens and uses that viewing angle for most modes. The 1080p mode is the only mode that uses a narrower angle of 127*.
    Here's a video that includes clips recorded in the 1080p mode: http://www.youtube.com/watch?v=2L_-bNm2Wrs&fmt=18
    Jun 2006
    Seacoast, NH
    186
    Pickles, here is a clip of my mount like yours breaking. I made it like yours after i saw your thread about it a while ago. Only lasted me about a half day of use till i broke it!
    http://www.youtube.com/watch?v=YqFP8moExCY
    Feb 2010
    Michigan
    174
    LOL... that's much better than the video of my mount breaking. The camera stayed in my car when mine broke. That clip is included toward the end of my video in the post above.
    I really liked the view from that mounting position. I think the same mount made of aluminum would be awesome.
    Jan 2010
    272
    plexiglass isn't that fragile unless you've given it some weak points to crack
    from... i'd bet it broke right where you screwed thru it?
    when bolting down such materials, always use a washer under the caphead
    with the gopro i like the lens centred, offsetting the camera body to the right
    saw somewhere once where they made a new battery plate as mount
    was thinking of folding some metal to make a tunnel over the battery
    but haven't had time to look more into it
    Jan 2010
    Green Bay, WI
    2,269
    Is there a camera for the slash 4x4 that is cheaper?
    PLEASE do not PM me and immediately go offline :p
    Jun 2006
    Seacoast, NH
    186
    Quote Originally Posted by Tamiya
    Should have mentioned that part of the GoPro mount broke. In the kit, it come with 2 low clips and 1 high clip. I have the high one on the truck at the time of the crash and it snapped it right off at the base. I've also broke one of the extension pieces. Guess it's time to order up some more parts!
    197
    anyone know if this will fit on the Slash with LCG chassie?
    196
    I use carb board on my battery mount wrapped up with eltrecial tape and then put the camera on and wrap it on
    Ill take more pics when i get home from school
    401
    I know I am going of the point but I have a youtube channel and I need more subscribers and I see that lot people that I have not subbed are making videos maybe if I tell my youtube channel you tell me yours?
    I am rustler1999929 Please sub Thx
    Ukraine
    17
    Quote Originally Posted by rustler1999929 View Post
    My youtube channel theguessua
    401
    Ok have you subbed any more?
    Quote Originally Posted by guessua View Post
