    Dec 2009
    111
    Question Diff oil for racing a tight track
    I am setting my 3905 up for racing......I have a brushless system and added a center diff. The package said the diff came with 200k oil
    But when I opened it it has a black grease.... no oil??????
    Any recommendations on oil combination for front rear and center diff's?....it is a tight outdoor track.
    I was thinking 150k center and 75k front and rear to start out...mainly because thats what I have around.
    Emaxx,E-Revo,4x4 Slash,2-Blitz's,Firestorm,Mini T
    Apr 2009
    555
    If im not mistaken the emaxx dont use diff oils !!! its just a grease
    IF YOU CANT FIX IT DONT BUY IT !
    516
    I am woundering the same thing. Can diff oil be used in the e-maxx diffs? Are they a closed system so that diff oil can be added?
    Sep 2008
    So. Cal
    1,322
    Sharpchuter 245
    Dyna Wide Glide
    Apr 2009
    555
    it will leak like crazy "been theri done that" That oil that they show are for outher traxxas trucks and cars ..................
    Sep 2008
    So. Cal
    1,322
    Quote Originally Posted by jaysd200
    If it is done right it doesn’t leak. I have re-built mine a couple of times each. In the instructions for rebuilding the Emaxx differential they call for using Traxxas Differential Lube. Here is a quote from their web site.
    Diff Lube
    Traxxas performance diff lubes make it easy to increase or decrease the limited slip action of the Revo gear differential. Depending on the track conditions, altering the limited slip capability can enhance turning performance for faster exit speeds. Each diff lube weight can be purchased separately as well. Revo is equipped out of the box with 30K W differential oil.
    Part #5136X Differential oil kit (1 each: 10K, 30K, 50K weights)
    Suggested retail price $21.00
    Part #5135 Oil, differential (10K weight)
    Suggested retail price $7.50
    Part # 5136 Oil, differential (30K weight)
    Part #5137 Oil, differential (50K weight)
    Part #5130 Oil, differential (100K Weight)
    Suggested retail price $8.00
    Part #5039 Oil, differential (500K Weight)
    Here is a copy of the re-build instructions.
    Sparky
    Sharpchuter 245
    Dyna Wide Glide
