Thread: MotorWoes...
    Browns Summit, NC
    187
    MotorWoes...
    Sooooo i decided id try out a venom 15d fireball..... gearing 16/86
    wow it was faster .. notice I say was .... well one full pack 7 cell 3000 mah traxxas battery and not even 1/4 way thru my Promatch 4600 7 cell and smoke was coming from the motor .. it was so hot the positive wire came unsoldered ....
    Hopefully wheni re solder it it still works, .. if not oh well 15 bucks poooo
    Zach
    Slash 2wd-RPM/STRC
    Stampede
    26
    yeah sounds like the 15t HPI i got. the negative wire broke up at the connector and then it broke at the motor. fixed both of them and i think the motor is burnt up... but it was only $6 shipped off e-bay and it lasted about a month so i didn't to to bad i dont guess..
    Apr 2010
    Grand Rapids, MI
    88
    If it lived you need to gear it down some, compared to the Titan it has no where near the torque but does turn more rpm...
    MoD SLaSH - 10.5T - 2S - Hellbent LCG Chassis
    Browns Summit, NC
    187
    ya, i figured 16 tooth from 19 was a good drop, apparently not .. i dont think its gonna work once i get it resoldered, as once it cooled down, i stuck the pos wire back on temporarily .. and once i went to throttle smoke started coming from the motor ..
    Zach
    Slash 2wd-RPM/STRC
    Stampede
    Jun 2009
    583
    thats exactly what happened to my orion it worked with my 6 cell but came unsoldered with the promatch 4600
    Dec 2008
    Gettin' Lucky In KY
    3,917
    Most likely your gearing is what fried the motor. I couldn't imagine a 15T 540 lasting very long in a heavy slash especially geared 16/86. Not to mention the Venom motors aren't the best out there.
    For a 15T 540 motor you should have been running a 12 or 13 tooth pinion.
