Results 1 to 12 of 12
Thread: servo torque
    Oct 2008
    Minnesota
    541
    servo torque
    how much steering servo torque should i have for 8.62in tall weighted tires truck probly ways 16lbs or so when crawling
    I have 333 right now, and its a joke, somehow i doubt going up to 600(hitec's new powerhouse servo) will be enough.
    T8 sensored/Xerun-150a/custom chassis/fit body
    Victoria B.C Canada
    5,478
    Quote Originally Posted by Brasher
    Are you useing one or two servos,Maybe two would be strong enough
    Mountains cant stop me
    they have tried
    3,546
    I second that - Two servos and dividing the load I feel is better than putting all the eggs into one high dollar servo basket. Im pushing dual 208oz (416oz) hobby city servos and they do pretty well. But I know hitec are very good as well. I believe the one servo setup is best suited in an attempt to lighten up the speedy revos.
    MAN, Use Common Sense.
    Outside? THERE IS NO BOX !
    Victoria B.C Canada
    5,478
    I'm running dual kershaws 231 each.Turning 40 series rock crushers.
    they have tried
    Jan 2010
    197
    Exclamation
    my .002c
    I'm ordering 2 of this for my summit.
    I'll have to work out how to tighten the servo saver or take it off completely somehow as this is my current problem....
    Rustler VXL & MM
    ERBE
    Summit
    and 6 more...
    Dec 2009
    59
    Quote Originally Posted by Z3r0
    my .002c
    Traxxxas part # 5344x. heavy duty spring. You might try it, if you haven't already. I used it when I went to a single servo setup.
    Caveman
    Hole in Rock, USA
    Jan 2010
    197
    Exclamation
    Quote Originally Posted by caveman4466
    my .002c my problem is the servo saver. It doesn't matter how strong the servo's are, if the servo saver kicks in, the wheels will not perform (turn) effectively and when you want it to.
    Thanks caveman4466... I'll order that too....
    Rustler VXL & MM
    ERBE
    Summit
    and 6 more...
    Oct 2008
    Minnesota
    541
    yeah the summit comes with the heavy duty spring, but the revos don't.
    you want to take the servo saver apart and drill out a washer so you can put it on the narrow spring side. add as many washers as you want, might need to get the aftermarket aluminum version if you want to put a lot though, because it will bend.
    Oct 2008
    Minnesota
    541
    my .002c
    wow, big spender lol.
    yeah id like to run two of those as well, but Id not like spending $300+
    yeah my 7955tg i think is called thats 333 at 6v, is kind of wierd it like jitters at the slightest touch, i have to go over to the truck and try to find the magic center buy turning the wheels left or right ever so slightly, so that it stops making noise.
    kind of think theres somthing wrong with it, ideas anyone?
    i wonder if hitec could fix it.
    Jan 2010
    197
    Exclamation
    Strange then, I have the problem in my summit not my ERBE. thanks for the washer tip.... I placed a flat 5mm diameter washer on the narrow spring side and placed a flat 10mm diameter washer on the wide side too. both are 2mm thick and fits perfectly.
    it performed better than it did. it was brilliant.
    IMHO, you only live once... i can always interchange it with my 8 trucks....
    My one is a bit noisy but I've read somewhere that that is normal for these powerful servos. They are quick and respond very well hence when you turn the TX wheel even just slightly, you will notice the truck wheels will follow. (well, my one does anyway)
    I adjust by using my DX3R and set my end points. works for me.
    Rustler VXL & MM
    ERBE
    Summit
    and 6 more...
    Feb 2010
    29
    Quote Originally Posted by jamann
    Do you use stock servo horns with kershaws servo?
    Summit (#5607)
    Sprint 2 Drift Sport (#761)
    Victoria B.C Canada
    5,478
    Quote Originally Posted by metapess
    Yep they bolt right on plug and play.I'm really happy with them so far.I've even submerged them a few times{Driver error} No problems so far.
    they have tried
