Results 1 to 21 of 21
    Apr 2010
    60
    1/16 Slash tires
    Are there any rim/tire options for the mini slash i can't find anything only these
    http://www.thetoyz.com/cart/thetoyz_...at_name=RC18T#
    T-maxx 2.5 , 1/16 Slash vxl, Slash PE, Rally??
    Apr 2010
    263
    There are not a ton of options unless you want to trim the body.
    For off road Kyosho mini inferno wheels and tires I think are bolt on no mods required. For on road you have a few more options.
    IF you do not mind trimming the body you can fit larger wheels and tires on there.. just look for 1/18 scale options. (Larger really helps the mini slash for general bashing.
    12mm hex, if you want to use the stock wheels you will have more trouble because of the offset on ID.
    Feb 2002
    9,027
    you can also use mlst rims, just need to get their wheel hubs too
    Jun 2010
    Lancaster PA....... NO i'm not Amish
    321
    yehhh those wheels u linked to are the the slash but there for fitting 1/18 tires to them, i used those exact wheels to add paddles tires to my slash
    http://monster.traxxas.com/showthrea...le+tires+found
    MERV VXL + Rally VXL + Stampede Xl5
    Apr 2010
    60
    http://www.thetoyz.com/cart/thetoyz_...7&cat_name=140
    Theres are the ones i'm going with, i'll paint them black once i get em.
    Should look good under JConcepts body, just got to figure out a paint scheme now
    Jul 2010
    Orange County CA
    109
    Hey Adamadam do the wheels you talk about fit on the Slash VXL with no mods needed?
    Apr 2010
    windsor ct
    72
    yeah no mod they come with a 12 mm hex so they bolt right up
    Upstate NY
    404
    There are quite a few options... any 1/10 touring rim fits perfect as long as they are 0 offset... and there are a few different 1/10 rally tire sets out there that are fantastic... I am currently running the HPI 4470 tires on mine...
    Heres an example or a couple different options...
    Left to Right:
    Stock, HPI Wheels and 4470 Tires, Jaco Foams
    The Bashing Grounds
    Ross M.
    5-Pointer!
    Jul 2010
    Orange County CA
    109
    Orgnoi1...I like the middle option. What tires and rim style is that? Any idea where I can get them?
    Upstate NY
    404
    Quote Originally Posted by BLKMRKT
    I am not seeing the HPI 4470 tires at AMain but I am sure that you can get them on eBay or somewhere... or basically look for ANY 1/10 rally 26mm tire set from HPI or Tamiya...
    Here is a selection of 1/10 touring wheels:
    http://www.amainhobbies.com/index.ph...&filter_mfr=16
    The HPI 4470 are 26mm tires so you will want 26mm wheels to go along with that...
    The picture I posted is actually a bit old... heres a couple new shots of the slash on the far right... first one is with Traxxas 4-Tec wheels (slicks)...
    http://www.northeastfoto.com/gallery..._05_12-R01.jpg
    Heres the two of mine together... dont let the angle fool you... the left one is slammed... its the same truck set up as the previous link... but this setup has the HPI Vintage 31mm tires and rims on it... its my play around inbetween racing my TC4...
    The Bashing Grounds
    Ross M.
    5-Pointer!
    Upstate NY
    404
    Quote Originally Posted by Jolio99
    Yes these will work...
    The Bashing Grounds
    Ross M.
    5-Pointer!
    Jun 2010
    8
    So it looks as if a 26mm rim and tire combo is stock. This is what we are looking for if we do not want to modify anything correct?
    What if we want to go larger? How large can we go in mm? What mods will be required?
    Also, what is needed if we want to use a wheel with an offset? What mods take care of that?
    Sorry for all the questions and jacking the thread but were all trying to learn here.
    Upstate NY
    404
    No problem at all...
    the MM rating is the width not the height... these are all 1.9" tires and rims so no modification should be required... I have 31mm on my onroad slash which are the ones in the picture... they are 3mm offset meaning that the outside of the rim and tire are not flush... they have 3mm of depth... stock slash wheels are the same "type" as the larger slash where it has 2.2/3.0... I am not sure what the outside diameter but the inside is 1.9 I believe...
    I actually have some BIG drift tires and rims (HPI LP35 and HPI LP32) but I havent tried to put them on my slash yet... if I make it downstairs to the work shop again I will try them out (currently on a broken ankle) but they should work just fine as well...
    The Bashing Grounds
    Ross M.
    5-Pointer!
    USA
    3,138
    I dig my hpi's, they worked great in the snow this past winter
    First MiniSlash
    HK6XL Revo 4s 60mph Amsoil dealer
    USA
    3,138
    I like my Jaco's to!
    First MiniSlash
    Apr 2009
    9
    what size are they. How much was that set up?
    Feb 2010
    13,335
    Quote Originally Posted by Orgnoi1
    My nephew has the same hpi vintage wheels on his mini. I think it looks great! Great street tires also
    Upstate NY
    404
    Quote Originally Posted by rustler23
    Jaco foams run about $13 a pair...
    The Bashing Grounds
    Ross M.
    5-Pointer!
    Upstate NY
    404
    Quote Originally Posted by El Sob
    Thanks! Yeah my only mistake was not balancing them before I ran them... so they have some flat spots... its a insanely fun onroad setup... I just need adjustable links...
    The Bashing Grounds
    Ross M.
    5-Pointer!
    Jun 2017
    6
    Treads wrong way
    Quote Originally Posted by filmmaker View Post
    . It looks like you have your front treads facing the wrong direction.
