Thread: EVX-2 question
    Feb 2010
    86
    EVX-2 question
    Today while driving, my EVX-2 just turned off. No green or red or flashing LED, just off. i could turn it right back on, but then after driving a minute or so, it would turn off. It did this about 7 times, so i packed it in.
    Great truck and Traxxas will flip my EVX-2 for $20, but i would like to know if anyone else can relate and what the cause was.
    Thanks
    Jul 2010
    England
    5,777
    Sticky power button, loose battery connection or solder joint, bad juju?...
    Feb 2010
    86
    Quote Originally Posted by ArmyofDarkness
    Button clicks up and down nicely, plus a sticky button would send it into program mode. Checked all the connectors. Won't accept "bad juju."
    Think'in about crack'in open the ESC to check it out.
    May 2009
    Southeast PA
    1,928
    The FIRST thing to ALWAYS check on EVX-2s acting up is bad servos! Touch those big steering servos and see if one is HOT .... or try unplugging one at a time and see how it reacts. Other smaller servos are the next to check.
    I make tap adapters and power harnesses.
    Feb 2010
    86
    i'll check the servos. i also just read in the manual to turn on the rx within 20 seconds of turning on the tx. Is the 20 second thing a must? It's the 2.4 with link.
    Thanks
