Results 1 to 9 of 9
    Feb 2010
    Spokane Washington
    208
    diff fluid question
    Ok so i decided to go with the steve slalyden setup. I bought some 5k diff fluid for the rear and 10 k for the front and some 60 wt shock oil. My question is how is the fluid supposed to stay in when the diffs arent even sealed. do i need to use some cyclone around the edges or what. and how do i put it in the diffs. Just remove the bottom bulkhead and then the diff is open?
    Slash 4x4
    Losi xxx-t Brushless
    PA
    520
    Your gonna need to pull out your exploded views that came with your truck for this. And what's the shock oil for? I hope that it's for shocks and not diffs.
    JESUS says: "Fix it B4 it Breaks!"
    Aug 2008
    Auburn, PA
    627
    The diffs themselves are sealed. You are thinking of the diff case/housing, that part isnt sealed. When you tear it apart, and get to the part in the pic below, that opens up with 4 hex screws and is filled with gooey goodness and all the diff fluid and gears inside
    Just refill that with the weight of your choice.
    I also put some wheel bearing grease on the ring and pinion gear (big, unsealed, external gear)before reassembly.
    Feb 2010
    Spokane Washington
    208
    yeah it is lol i got diff fluid and shock oil. tryin some new setup
    Slash 4x4
    Apr 2010
    171
    The diff is where the spider gears are, not the ring and pinions.
    Feb 2010
    Spokane Washington
    208
    thanks alot skepply i really appreciate it!
    ok so i just took it apart. Now do i wash out all the old stuff and will team associated 1000cst diff fluid be good for the front and 5000 for the rear?
    Slash 4x4
    Jan 2009
    Prince George, BC
    314
    Quote Originally Posted by ktm11rider
    Yes clean it out as much as you can. If you are going with the Slayden setup, just put in what he recommends.
    Feb 2010
    Indianapolis
    14,198
    Don't worry a lot of people have made the same mistake. We are here to help not tease.
    Apr 2010
    171
    Exactly bother's of slash..
