Page 3 of 3 FirstFirst 123
Results 81 to 90 of 90
  1. #81
    May 2006
    DENMARK
    1,401
    That's the HPI Datsun 240Z with the long wheel base
    The Tamiya Datsun 280ZX is 184mm wide and wb is 210mm
    Morten
    Morten SnoopMaxx
    3906 ROCKSTAR Makita
    c",)
  2. #82
    Nov 2008
    Toronto
    301
    You might be right! The wheelbase of the rally is 206 and the wheelbase of the body you have shown is 210.... that should fit fairly easily.
    Check this out!!!
    http://www.abchobby.com/abcframe/inf...ges/swift.html
    This body is 208mm only 2mm longer!! Rally body too. Should fit!!!
  3. #83
    May 2006
    DENMARK
    1,401
    NOPE ...163mm wide
    Morten
    Morten SnoopMaxx
    c",)
  4. #84
    Nov 2008
    Toronto
    301
    Quote Originally Posted by SnoopMaxx
    NOPE ...163mm wide
    Morten
    you're right... ughh I was just getting excited..
  5. #85
    705
    Quote Originally Posted by tmaxx_cnd_newb
    I have cup racer... lol! I'll just see how the datsun body would sit on my erevo vxl without wheels. Pic to be posted tonite.
    You have the Tamiya? I was thinking about getting one (the Datsun)! You like it? Sorry to get off the Traxxas topic...but would LOVE to see Traxxas come out with this in 1/10th scale!
    If you can't beat it....destroy it!
  6. #86
    champlin mn
    540
    now tower says late october
    Big Block KB
    ERBE Tekin rx8
    MERV Basher
  7. #87
    Nov 2008
    Toronto
    301
    Quote Originally Posted by kaceywells
    I have the HPI cup racer.. no tamiya.
  8. #88
    May 2009
    SE Michigan
    175
    I too am planning to convert my Mini Slash to the Rally VXL. My modified mini Slash was developed for carpet racing and the high motor position was a problem at first. When I created the low CG chassis and mounted the battery, ESC, Receiver and servo to the lower plate this chassis was alive and jumped very well. I was considering a 10th scale 4wd buggy center diff to lower the motor but then battery size would be real challenging. My design could almost fit a standard 10th scale Lipo on the drivers side. With the Rally body it will fit fine.
    This is truely a short 10th scale vehicle or maybe 12th scale. The 185mm width is very close to the 190/200mm touring cars. The 206mm wheelbase is much shorter than the 256mm+ touring cars but so what. It's a Rally car with real capability. Seriously, you will have all the hop-ups for this chassis based on the mini Slash and mini E-Revo!! I had shelved my Mini Slash to focus on racing off-road 10th scale but now I want to trick out a Rally VXL and see if my local carpet track wants to start a racing class! Imagine a 40x60ft Special stage Rally track were two drivers go head to head like WRC!
    Hop-ups desired:
    1) RPM hub carriers
    2) Traxxas CVDs and center CVA
    3) Center Diff
    4) Traxxas GTR shocks
    5) Tamiya and HPI tires depending on track surface
    6) Clear body to paint up my design
    Are the new BFG tires good on carpet?
  9. #89
    May 2006
    DENMARK
    1,401
    Quote Originally Posted by Stockslasher
    Have you ever seen the ROC Race of Champions ??
    Morten
    Morten SnoopMaxx
    c",)
  10. #90
    May 2009
    SE Michigan
    175
    Morten
    Yes!!! That's what I'm talking about. My local Hobby shop has a bunch of Slashes that they use for birthday parties on their carpet track. It would be so cool to have a ROC like the video shows bringing top drivers to the shop and run a Super Special track. The Rally VXL stock with the stock battery would be good enough. My Mini Slash VXL was almost un-manageble but the stiffer springs should make a huge difference.
    I already set the shock oil to 50wt and lowered the suspension like the Rally which is required. I also went to the stiffer Slash springs. Would be fun for sure.
