That is...beyond crazy, in fact it's insaneAre there any videos?
Prepared a set of springs with shocks. 32 pieces for the entire machine.
Traxxas Shocks E-MAXX TRA4962 Big Bore with E-Maxx Black Three Rate Springs Set Krohpit Editions three times stiffer original - 5kg compression instead of 1,6kg in the original E-MAXX.
Top part of the frame.
That is completely crazy cool. However, tell me you're planning on putting in some sort of vertical articulation? Climbing over ramps/hills/bumps you'll lose 50% of the traction I'd expect?
Your builds are always insane though so I can't wait to see =)
Adjust the steering servo.
Each wheel is the personal drive for implementing additional functionality Control as it was on the BTR-80.
Now axes are controlled similarly to the original car - 1,2,3,6,7,8.
The axes 4 and 5 are fixed, but the servo mount made for the future.
Installed servo for shifting gear in the gearbox.
Comparison with a plastic model of the old Topol scale 1/72
Load test frame
WOW standing on it like that is IMPRESSIVE! What a beast
Installed motor-generator to the frame with rubber mounts
Made my first music video. Anthem of the Russian Federation - the drumer is tank BTR-80
https://youtu.be/NZtf3PxAS6U
https://youtu.be/dHflMm1EkzY
Place the cooling system.
As a fan - 50mm EDF
Provisional connection of the control system
Additional PWM controller to increase the number of outputs to actuators, connected via I2C bus
Servo BEC
Now the picture has turned out not presentable
I write the firmware for a test drive ...
To set up a hybrid system - made the automatic load test stand.
http://www.krohpit.ru/2015/05/load-test-eng.html
Extreme talent.... Speechless...
What are the parts to add the last two wheels? (gearbox, shafts, drive shafts.....etc).
I need it for snow crawling torque duties
can we see a video of your new projects.
SLAM!
"That Tree jumped right in front of me"
Thats crazy man! nice work.
SLAM!
That's amazing, looks like a ton of fun to drive, is the engine supposed to act as a generator to power the motors, like a locomotive? If so that's probably the coolest thing I have ever seen I have seen on an RC.
