Results 1 to 14 of 14
Thread: Lipo Chargers
    Sep 2010
    162
    Exclamation Lipo Chargers
    I recently bought a 1/16 slash ( i know wrong forum but this has more traffic and this applies) and i run 2 3s batteries at once. Each one takes an hour to charge. Any recommendations to chargers that charge more than one lipo at once?
    thanks!
    - Grant
    Aug 2010
    Belle Chasse, Louisiana
    215
    yup...mine does 4 at once, any kind of battery,..and was under $100...PM me..
    http://s405.photobucket.com/albums/pp138/TANKS250/
    May 2009
    Southeast PA
    1,932
    Calculate the amperage and wattage needed and buy a charger that can deliver that!
    Say you have 2S 1600 mAh packs = 8.4 volts @ 1.6 amps = 13.44 watts
    two in parallel = 8.4 @ 3.2 amps = 26.88 watts
    four in parallel = 8.4 @ 6.4 amps = 53.76 watts
    six in parallel = 8.4 @ 9.6 amps = 80.64 watts
    6 each 3S 1600s in parallel = 12.6 @ 9.6 amps = 120.96 watts
    Series is best left to two packs in Series ... for 2S + 2S = 16.8 volts @ 1.6 amps = 26.88 watts
    Accucel-8 will do 7 amps @ 150 watts
    iChargers will do .... pretty much depending on unit (30 amps and 500+ watts)
    FMA Power Lab 8 will do 30 amps and 1000 watts
    Of course you will need a big power supply.
    iCharger 206B with PS350 power supply is one of my favorite combos. 20 amps and 350 watts.
    http://www.youtube.com/watch?v=NczQwVTI2bY
    Bob
    Sep 2008
    Stockton, Ca.
    928
    I can do 2 in parallel with my basic 50 watt charger
    If you want to charge more than 2 batteries at one time Use the info in Hughes500Bob post if you have a charger with more watts or are buying one
    [IMG][/IMG]
    Jun 2008
    Winnipeg, Canada
    1,048
    Yeah but your packs still ring in under 5000mah.
    Try that with 2 5k packs and see how long you wait
    Mine will do 2 at once, 180w per port, but you need an external psu.
    May 2010
    Nebraska
    148
    This is a great post. I would love to charge two 3s lipos at once. But I thought I read somewhere to never do that. I would love to be able to charge them as one battery. they are 1500 3s Max amps. How do I charge them together at once. And is that risky?
    Jul 2010
    England
    5,777
    Its not risky at all, you just have to charge them in series rather than in parallel. Talk to Huges500bob and he can sort you out with a suitable charging adaptor- you can make your own ( CLICKY ) but its best to buy one from a trusted source if you arent all that confident.
    Aug 2009
    Spruce Grove, Alberta
    1,552
    Quote Originally Posted by kirkhayes37
    In reality, by using the proper adapter, all you are doing is tricking your charger into thinking it is charging a single 6s pack. you need to make sure you have a 6s capable charger and you would be good to go.
    http://traxxas.com/forums/showthread.php?536733
    May 2009
    Edmonton, Alberta
    3,663
    its the standard taps yeah. they have them prebuilt for 2s = 4s and 3s = 6s and with TRX, Deans and EC5 connectors
    May 2009
    Edmonton, Alberta
    3,663
    Ill be darned, they are too. i never looked that close, not even thought. They have them hanging right next to traxxas packs of replacement leads so i just assumed.
    Aug 2009
    Surrey, England
    65
    I second Hughes500Bob, iCharger 206B and charge the packs in series, works for me.
    Too many to list
    Jun 2010
    32
    is Huges500bob a member here?
    kansas
    8,683
    check the third post that is BOB
    May 2009
    Southeast PA
    1,932
    With the proper harnesses .... NO It is not risky at all!
    You can charge your 2 3S 1500 packs with a Series rig (both power and balancing) at 6S @ 1.5 amps for a 1C charge rate = 25.2v @ 1.5 amps = 37.8 watts.
    You can charge your 2 3S 1500 packs with a Parallel rig (both power and balancing) at 3S @ 3 amps for a 1C charge rate = 12.6v @ 3 amps = 37.8 watts.
    Either way is perfectly safe.
    Bob
