    4
    traxxas t maxx 2.5r ran about 15 minutes and bert out glow 3 glow plugs
    does anyone have a clue why it is doing this. its cold here and i am running hot glow plugs.
    13,498
    Since it is cold out, are you leaning out the engine to get decent temps? You may have to richen it up and cover the head with a sock or tin foil. Hot plugs do not automatically make the engine run hotter.
    Feb 2002
    Central New Jersey, USA
    13,880
    I agree. Too lean. Start by running a body with no cut outs in the windshield and richen up the main needle by about 1/2 turn and re-tune from there.
    At least the plugs blew before the engine!
    (how cold was it when you were running?)
    Speed costs money, how fast do you want to go?
    Jan 2008
    Sugar Hill Ga.
    8,397
    3 plugs in 15 min + the same/previous problems you had with the cold plugs would lead me to believe there is an internal problem with the engine: Debris floating around inside the combustion chamber from a bad Crank bearing or broken piston skirt will kill a plug quick.
    Hopefully it is just tune related (lean), richen the tune and see if the problem persists. If it does, its time to tear it down and have a look at the internals.
