Results 1 to 12 of 12
    Sep 2010
    37
    steering backwards
    Went out to use my VXL Stampede with my 6 year boy a couple of his friends and somehow the steering got screwed up.
    When i steer right it turns left and when you turn left it goes right.
    Would anyone be kind enough to let me know how to reset it so it steers correctly.
    Thanks,
    snookuda
    May 2009
    Southeast PA
    1,932
    Slide button on TX that reverses the channel 1 servo was bumped.
    Sep 2010
    37
    I have the Stampede VXL with traxxas link TQ transmitter.
    Can you be more specific on this slide button. On the bottom of the remote control i have the on/off slide button and a menu and set button.
    Im not sure about a channel 1 servo, is it on the transmitter or truck?
    Thanks,
    snookuda
    Oct 2004
    Southern California
    283
    On the TQ you have to go to your manual and find out how to push the button sequence to reverse steering servo.
    Mine keeps switching back and forth. Really a poor radio in this regard.
    In fact, mine is so bad, I had to write the code sequence on a piece of paper and tape it to the bottom of the transmitter, so I can switch it when necessary. Always an unplesant suprise when it is reversed.
    Traxxas really dropped the ball on this one.
    Dennis
    Jul 2009
    Ontario, Canada
    11,293
    Most questions like this can be easily and quickly answered by looking in the manual first. Most of the answers youll get will just be what is listed in the manual anyway. Youll be surprised how helpful and thorough the manual is with these trucks.
    Dec 2008
    Ohio
    293
    The manual is certainly helpful on how to fix this but there is a bug in the radio that causes this. Ours switch on their own occasionally too. Many others have reported this and I wish Traxxas would address the problem.
    Aug 2010
    Inver Grove Heights, MN
    1,540
    Seems to happen to us all. Luckily mine only did this one time! It would really be really bad if the trim got out of whack all the time ;(
    Then there would be a super annoying problem.
    But reversing the steering once a month or even a week is not to big of an issue.
    So I taped my hamster to the Pede..
    Dec 2008
    Ohio
    293
    Oh btw... Merry Christmas everyone. Hope you all got lots of rc stuff! My kids each got a new boxed vxl system and new bodies.
    RC Champion dave00bear's Avatar
    Jan 2007
    Michigan
    1,935
    I myself have never had a issue with the 2.4 link system. Once I set everything up it has always stayed that way.
    But here is the procedure taken right from the manual:
    To REVERSE the direction of the STEERING servo
    Press and hold MENU; green LED blinks
    Press MENU; green LED blinks (x2)
    Press SET; green LED blinks
    Press SET; red LED blinks
    Press SET to reverse servo direction; green LED blinks (x8)
    Press and hold menu; returns to driving mode
    My previous sig conflicted with a forum policy.
    Central NJ
    343
    When I had this problem this is what I did:
    transmitter OFF
    Hold MENU and SET
    Turn transmitter ON
    Release MENU and SET, red led will blink
    Press MENU and red LED blinks twice
    Press SET to clear settings. LED will turn solid green. Transmitter restored to default
    This is how to restore it back to factory default. Its in the quick reference guide and it worked for me
    1 extended pede
    1 stock length pede
    Summit
    Jul 2010
    293
    The restore to factory default is the temporary fix. It's apparently an ongoing issue for some including me.
    Sep 2010
    37
    thanks guys,
    i think dave00bears suggestion worked.
    I had misplaced my hardcopy manual and downloaded it from online.
    after fixing the steering, somehow the throttle forward and reversed got switched, but i was able to get it working and now have printouts on how to fix.
    Thanks,
    snookuda
