Results 1 to 12 of 12
    houston
    29
    2650kv mamba monster gears?
    I have a slash 4x4 with mamba monster 2650kv on 4s and almost every time I run I strip out my spur gear, so if anybody has any suggestions on different gears than please let me know.
    Dec 2008
    Melbourne Aus
    1,925
    You should not be stripping gears if the mesh is set correctly
    How tight are you running your slipper clutch ?
    Cheers
    Slash Platinum
    SCT MMP / 2400kv
    RC Turnbuckle Jr. asheck's Avatar
    Nov 2007
    Kansas City
    7,360
    The stock spur should be fine. They are the same ones ran in the 10+lb E-revo. I would look at either improper adjustment, or the motor moving, for the cause.
    _
    _
    _ 3 lines are all that's allowed in a sig.
    Aug 2008
    Auburn, PA
    627
    i agree. its the same spur(besides tooth count) used on the erevo brushless. it should have no problems on 4s and such a light truck.
    maybe your motor mount bearing is going out and giving some play.
    Ontario, Canada
    1,249
    What are you using for a pinion gear, Type and ratio ?
    Al
    MMM/2650, E-maxx Body=FUN !
    3 Slash 4x4
    Pede 4x4
    houston
    29
    Quote Originally Posted by crusey_aus View Post
    Cheers
    Not very tight
    Dec 2008
    Melbourne Aus
    1,925
    If your spur and pinion are lined up correctly and meshed well you will not strip spurs
    Cheers
    Slash Platinum
    SCT MMP / 2400kv
    69
    On the subject of gear meshing do you guys use the notebook paper method?This works good for me with smaller pinions but when i installed my 18 tooth pinion theres seems to be binding so i roll the truck and set it that way with the larger pinions.
    houston
    29
    Well you guys obviously have never had a 2650kv mamba monster in your 4x4 slash with 4s lipo cause i have done the mesh perfect and even had the guys at my hobby shop do it
    Nov 2007
    Kansas City
    7,360
    Baaa, the 2650 in the Slash on 4s is nothing. I have ran the exact same spur gear ,54tooth, in a E-revo, that weighs twice as much, with the 2200 motor, which is bigger then the 2650, with Big Joe tires, that weigh 1/2 pound a piece, on 6s, and it held up fine.
    So as we said , either you are not setting your mesh correctly, which you assure us you are, or you need to look for another problem. Slipper, bearing, motor movement, ect, there's lot's of possibilties.
    _
    _
    69
    I run mine with thw 2200kv on 4-6s sometimes and havnt had a mesh issue.If it where me i would try and hold the truck in the air and let someone throttle it and maybe shake it to see if somehting did move even though castle dosnt recommend this but thats what i would do, but than again i am very very strong and i know i could control it under wot, just a thought goodluck!
    Jan 2003
    nc
    2,383
    I have the 2650 in my slash 4x4 on 2-4s lipo and no probs here with gears. I'm running locked slipper also.
    slash 4x4 163mph
    youtube:philip jolley
