Results 1 to 11 of 11
    panama city fl
    125
    Exclamation steering servo hot and fading
    both steering servos went out at once. i replaced with trx. # 2075 as they worked well for the past 6 months. and the same thing happened today, i installed them and all was ok and i went to bash and then 15 min. later truck started pausing so i pullede it in and checked the servo heat and the same one that waws heating up was hot again and fading on turning right. please help . is it the receiver wired wrong or just bad servo. i called traxxas and he said he didnt understand and is sending anther servo to me. gotta love traxxas for that. any help would be great. thank you all.
    May 2009
    Southeast PA
    1,932
    Did you adjust the steering linkage (per the manual) so the servos were not fighting each other (buzzing)?
    panama city fl
    125
    yes i did and they were quiet no noise. thanks
    panama city fl
    125
    well it cooled down and i turned it on just to check and see if it got hot while in use, but as soon as i turned on the esc the left side servo started heating up, while sitting there . no noise, servos are centered.
    Dec 2009
    Pa
    774
    sounds like you possibly have a binding going on inside the servo case. maybe try opening up the servo case and see if something isn't binding the gears or possibly you might have a bent shaft that would stress the motor in the servo causing it to heat up on startup.
    Revenge 1/8 buggy
    May 2009
    Southeast PA
    1,932
    Servos do go bad! They do strip gears! If it is getting hot it is definitly bad.
    Traxxas will replace all electronics out of warranty at 50% value.
    Often cheaper to buy some spares off of E-Bay "chop shops".
    Bob
    Jul 2010
    England
    5,777
    Replace 2x naff stock servos with 1x awesome single servo = happy days:
    http://traxxas.com/forums/showthread...-Now&p=4666998
    http://traxxas.com/forums/showthread...65#post4667865
    panama city fl
    125
    thank you Armyof D
    321
    yeah, I have been through countless 2075s (ok 4 or 5) so I am going to the single servo also. All we do is rock crawl and there just isnt enough tourqe on the traxxas ones for serious stuff anyway..
    Make sure to post up what you chose to run and how it works out for ya!
    panama city fl
    125
    ******* HV767 $70 only 1 and it works great also put the heavy duty servo saver spring. It has 338 oz. torque at 6v im pleased
    148
    I just put in a HV767, read more in thread below
    http://traxxas.com/forums/showthread...ng-servo/page2
