    49
    Motor mount and spur gear question
    I broke my motor mount today and the spur gears teeth are awfuly flat. You have to press the clutch bell gear tight against it so it will turn. Anyway, is there any reason not to buy a billet alum motor mount and a steel spur gear.
    thanx
    chad
    13,568
    Stay away from the steel spur. With a proper mesh it will last a long time. But if you want to go steel, expect to replace transmission gears instead.
    49
    Thats what i was wondering. Sometimes going strong in one area weakens another
    Jan 2001
    Fresno, CA
    2,018
    im not sure about the stronger motor mount might end up breaking the motor case instead of a mount. as far as the steel spur im with G on this one as well.
    3.3 t-maxx, O.S. .18TM t-maxx, HV brushless e-maxx
    Feb 2006
    In the mountains
    1,633
    I run the traxxas billet mount, and i also have the steel spur on my truck. Never had an issue with the spur or transmission, i did always manage to destroy clutch bells if the mesh wasnt right....
    Retired RC'r till funds can be found...:(
