Results 1 to 7 of 7
    mighty old england
    157
    Steel foc for revo.
    Hello ive just received the last 2 gears to have a full*rrp steel foc but since I brought them individually im thinking im missing parts. The full foc all in one price shows a metal collar or something which I haven't received.
    Will that be inside my standard foc box already I can just reuse of will I have to order it and if so where from.
    To grease them after install ive been reccomended black graphite grease which has a push bike chain and gears picture I hope it will be ok for rc. I know the specific rc liquids are usually a rewrap of motor liquids thobso hopfully it was a good buy since I couldnt find any rc branded black grease here.
    7,264
    the aluminum collar should come with the RRP kit.
    SD California
    1,157
    Lubing the trans with liquid graphite won't hurt anything. It goes on as a liquid and drys into a powder. It also won't attract dirt like normal grease/oil.
    mighty old england
    157
    What a trip yes I think I do have it actually its just smaller than I expected in with the 2 foc gears theres a small collar but I was looking for a bigger diameter.
    Alls well then I can tear it down tonight.
    Any help on setting the shift point ir even better a guide on doing it. Or factory setting if there is one
    I went with the wide ratio set so may need to stretch the change too mayb.
    Thanks for posting
    mighty old england
    157
    No its the alloy spacer I have is that it?
    Edit.
    Ive just looked again and yeah I do have it thats ace I also got alot of shims.
    Is there any guides on here installing the steel foc I can follow along with so I dont mess it up.
    7,264
    if you don't have this shaft, you wont be able to install your FOC gear
    http://www.ebay.com/itm/Traxxas-5369...item58a323eab4
    this is my Wide ratio gear also that I don't have anymore.
    mighty old england
    157
    Thanks I do have s shaft from when I removed reverse is that the one I need to put back in? The gearbox has a traxxas foc in now but I kept all of the reverse stuff.
    Any good threads on this install I can follow would be great.
