Page 4 of 5 FirstFirst ... 2345 LastLast
Results 121 to 160 of 171
Thread: T-maxx build
  1. #121
    Aug 2010
    157
    it has good trail on high speeds, @ TLC > will try your method of testing the temp with water droplet. thanks guys for your help.
  2. #122
    castalia ohio
    5,685
    yeah, havent tried the water droplet one myself. but i bought a temp gun on day one. i would also have to say either faulty gauge or not set up just perfectly like those require.
    Drag It!
  3. #123
    Jul 2011
    Northern Cal
    311
    Quote Originally Posted by 08kgraves View Post
    LOL My buddies call it the redneck temp guage, or Hillybilly spit method.
    Its crude it it will get you by in a pinch.
    @maximus I'd look into a temp gun, They're a much more reliable tuning guide
    than a drop of spit or an onboard meter for that matter.
    My Karma runneth over your Dogma.
  4. #124
    Aug 2010
    157
    i bought the on-board one coz i don't have to carry it . i installed it as per the instructions provided with it.now i think i have to buy one hand held sensor.
  5. #125
    St. Louis
    235
    Quote Originally Posted by Snook Man View Post
    Thats a nice start.
    You will need to move the front toe links to the bottom side of the axle carrier arm for improved steering.
    Does anyone have a picture of the configuration? I am not sure I understand.
  6. #126
    Aug 2010
    157
    Quote Originally Posted by Tankdg View Post
    will post once i click it
  7. #127
    7,264
    to my understanding is that instead of screwing the end of your front toe link on top of the axle carriers arm, you screw it to the bottom.
  8. #128
    Jul 2011
    Northern Cal
    311
    Ignore the busted pivot ball...
    Notice how the turnbuckle rod end is attached to the bottom of the
    axle carrier arm. Like this..
    not this...
  9. #129
    Aug 2010
    157
    small question...
    does reducing the antenna effect the range. i am using traxxas 2.4 ghz. every time my truck flips over the antena gets bent so i want to keep it inside the body or reduce the size...
  10. #130
    castalia ohio
    5,685
    mine came brand new with a 2.4 setup and my antenna tube came stock without even exiting the body. just leave it a little below the body so if you land on your lid and it flexes the body wont compress the tube at all and damage the antenna tube.
    Drag It!
  11. #131
    Jul 2011
    Northern Cal
    311
    Cutting the antenna will reduce your range.
    If you have a pickup truck style body, drill a small hole in the rear window.
    Run your antenna tube through the hole, then your tube is horizontal, not vertical
    and less likely to be damaged.
  12. #132
    castalia ohio
    5,685
    with my 2.4 system i still have full control so far i can barely see it. but yes TLC is right..... do not, i repeat do no cut the antenna itself. you can shorten the tube but not the antenna wire.
    Drag It!
  13. #133
    7,264
    with 2.4ghz 2" is all you need lol.
  14. #134
    castalia ohio
    5,685
    yup mine came that length stock
    Drag It!
  15. #135
    Aug 2010
    157
    sorry for saying shortening the antenna i meant shortening the tube. so if i shorten the tube it will not effect the range, that's cool.
  16. #136
    7,264
    the only time i have problem with mine was weak battery on remote, lol. lost its range and the truck keeps on rolling good thing the parking lot is wide long and empty.
  17. #137
    castalia ohio
    5,685
    well if you have the 2.4 system with throttle return spring it should bring it to a stop. never actually ran out of range on mine. i know on my older maxx with the added fail safe it actually applies the brakes if i start going out of range
    Drag It!
  18. #138
    Aug 2010
    157
    i have a throttle return spring on my truck, actually never tested its range,how many meters is the effective range of this system.
  19. #139
    castalia ohio
    5,685
    couldnt tell you lol, but i can tell you that i have 20/20 vision and the range on mine is far enough that i can barely see it and it still works. which is way farther away then i would ever have it when in opperation lol
    Drag It!
  20. #140
    Aug 2010
    157
    guys finally the moment came.i took time to get my Proline helios body painted(its kinda crappy paint job as this was the first time)
  21. #141
    castalia ohio
    5,685
    about time man, do you know how long ive been waiting to see that body on there? especially since i used to be a huge halo fan lol.
    i like the look with the wing but i think the wing needs to be black to match mutch better. but overall i like it.
    Drag It!
  22. #142
    Aug 2010
    157
    i like the color of the wing coz of the bling...lol. it took lot of time for me to paint it,the olive drab was not available,and i was busy with lot of things...it just looks awesome
    watch the full album http://s766.photobucket.com/albums/xx309/maximus_bash/
  23. #143
    castalia ohio
    5,685
    yeah that was just my opinion. if your happy with it then thats all that matters, dont let anyone try to tell you to do something you dont want to. but it never hurts to get ideas atleast. thats what this place is all about after all.
    Drag It!
  24. #144
    Aug 2010
    157
    thank you all for your help.i got a pair of aluminum threaded shock bodies and i replaced the stock ones with the aluminium ones now the rear end is lil stiffer. and i hope it will help in jumps and while on two wheels....
  25. #145
    Aug 2010
    157
    hey guys i was doing some research on tuning and found that putting a fuel cooler on the fuel line will help in reducing the temp of the fuel entering the carb and will hold the tune better, and adding another on on the pressure line will be perfect.
    what do you guys think does it work well ?
    4910 T maxx 3.3
  26. #146
    Jun 2011
    Lucas, Ohio
    722
    Only thing I could see being an issue might be the possibility of an air leak where your fuel lines hook up.
    Joshua 24:15 Choose this day who ye will serve
  27. #147
    Jun 2011
    Lucas, Ohio
    722
    If you are using an on board temp gauge, be careful I know a guy who had a revo and his gauge said 340+ so he replaced the engine even though all signs said the engine was fine(good smoke trail no high rpm cut out) and low and behold the gauge said the same thing on the new motor. Long story short the on board gauge was just faulty.
  28. #148
    Jan 2008
    Sugar Hill Ga.
    8,397
    Quote Originally Posted by maximus9 View Post
    Cooler fuel is denser than warmer fuel. Denser fuel has more fuel molecules per volume then warmer fuel (you can fit more cool fuel molecules than warmer fuel molecules in the same space). Cooling the fuel alone will only add more fuel to the air/fuel mix.
    More fuel with the same air temperature/ratio will richen the tune.
    The (gimmick) fuel coolers installed on a Nitromethane RC fuel system will do very little in the way of cooling the fuel anyway.
  29. #149
    castalia ohio
    5,685
    yeah i agree with snook, theres not even enough time really to cool the fuel anyway. and the inline filters are just prone for an air leak. im going to take mine off soon anyway since i have a filter in my tank now.
    Drag It!
  30. #150
    Aug 2010
    157
    thank you guys i was so much convinced i almost bought one for my truck then thought of asking you guys about it.
    i am facing another minor problem, the throttle link post becomes loose very often i even changed the screw but the problem reapers.
    4910 T maxx 3.3
  31. #151
    castalia ohio
    5,685
    are you using locktite on it?
    Drag It!
  32. #152
    Aug 2010
    157
    i remember reading not use locktite on the plastic parts.you recommend me to use it
    4910 T maxx 3.3
  33. #153
    castalia ohio
    5,685
    Some people say not to but I use it anywhere plastic or metal and I have never had a problem. Especially good in the bilkheads where they bolt to chassis if u run stock bulks.
    Drag It!
  34. #154
    May 2009
    Colorado
    685
    Normally it's not needed on plastic parts. If your's keeps coming loose, I'd go ahead and use it or get a new post.
  35. #155
    Aug 2010
    157
    ok i will do it today and check
    4910 T maxx 3.3
  36. #156
    Marshal carraig042's Avatar
    East Tennessee
    6,765
    I did not think threadlock would work at all on plastic parts. I have used super glue on screws in plastic before and it worked well.
    -Brett
    4wd Sportmaxx 3.3
  37. #157
    Jun 2009
    Cocoa Florida
    4,908
    Either superglue the screw into the post or get a new plastic post.
    Look out for the tree/crunch!
    LiPo? Naw NITRO!!
  38. #158
    castalia ohio
    5,685
    its up to you but i can tell you that it hasnt hurt anything when i put on plastic, and it did work. but thats what i would try
    Drag It!
  39. #159
    Jan 2008
    Sugar Hill Ga.
    8,397
    Usually a longer screw is all thats needed in the throttle bellcrank.
  40. #160
    Aug 2010
    157
    Thanks snook i just did that nd its holding good now
    4910 T maxx 3.3
