Results 1 to 14 of 14
    Biloxi, MS
    1,549
    Question To wd-40 or not to wd-40? That is my question.
    Any insights. Ive heard it both ways, whats the truth? For motors? Bearings?
    Merv, Sl4sh, P4de, Embe, Slash
    2400/2200/4000kv
    ND
    526
    Bearings yes. I always do.. Or use this stuff.. Best stuff i've found so far....http://www.schaefferoil.com/specialty/190_Penetro.html
    2,334
    It really does help with rust protection, but it will get messy if you get it on the chassis and plastic parts. This is from bashing in dandelions with WD-40 on my axle carriers (accidentally got on there):
    If you get the new WD-40 can with the Smart Straw, it's really easy to spray those small bearings and parts that need to be sprayed down. It will smell for a little while, but the smell will go away.
    I love the stuff!! It works really well!!
    Sep 2009
    Lancashire - UK
    656
    The only thing on my merv id wd-40 is maybe bolt/screw heads to help prevent rusting but i would not use it on bearings or anything like that to reduce friction that a proper oil/grease is intended. Ive heard a light wd-40 mist over the rc chassis is a good idea after cleaning to help easy dirt removal.
    MERV│
    MAMBA MAX
    ND
    526
    Quote Originally Posted by KILO-DELTA View Post
    This is true, people use it all the time on the inner fenders of off road rigs to help the mud wash off..
    Biloxi, MS
    1,549
    So not on the motor? How about electronics cleaner?
    2400/2200/4000kv
    Okinawa, Japan
    41
    Quote Originally Posted by Dr.J View Post
    I've used electronics cleaner on my motors, no problem.
    Jun 2010
    Miami, Fl
    6,731
    excessive oil will atract dirt, and more problems
    2,334
    Probably just a light mist will attract less dirt on the electronics and such, though.
    California
    4,902
    i use it all the time with no problems helps to clean wheel and rims good.
    Living life.
    Jul 2009
    Quebec
    374
    If you run in the wet... You must use WD-40 to prevent the steel parts from rusting. Go ahead, use it!
    What have you learned today?
    Bay Area, CA
    438
    I've only used WD40 to blast out the bearings. I soaked metal bits in this stuff and have had success... no rusting since, and grit doesn't stick. It's been very good for the pillow balls:
    The prototype project.
    RC Champion trax de max's Avatar
    1,949
    i use p.t.f.e. spray.
    wd40 can affect some plastics.
    14
    ive sprayed wd40 on my merv and rally, after i washed it and air dryed it. When im done with my jetski, cuz i ride in saltwater, i normally spray CRC 656..and i know that stuff is ok with plastic parts, so i might try spraying that on my rc cars after i wash them. Plus its a lubricant and its good stuff.
