Results 1 to 19 of 19
    USA
    457
    My final solution to the Integy Center Drive Shaft failures
    As most everyone knows, the Integy Center Drive Shaft has a pin that will fly out if you don't cover it with something. I had previously applied super glue in and around the pin to keep it from flying out along with three layers (yes, 3 layers) of heat shrink tubing for even more protection. Well I was out running 3S lipo last night and the pin came out again. So that just isn't going to work. As you can see in the picture, it created a nice little cut out section in my chassis. So I went to the hardware store today and found some aluminum pipe tubing that was just the right size to cover the pin on the drive shaft. I had to squeeze it on there and I don't think it will ever move. It's just thin enough to not rub on anything. So this is what I would recommend for those with this drive shaft. It was $0.65 for 1" of pipe and I just cut it to length with a dremel.
    May 2009
    Edmonton, Alberta
    3,663
    very nice, heres hoping it stays in place. Did you add anything to keep it there or is it just tension?
    Rotterdam, Netherlands
    8,622
    Cool mod. Do I see an alu bulkhead there? I wonder if they work well.
    United K
    1,042
    I'm interested in the aluminum bulkheads as well. Are they any good?
    34
    I had a better solution, I threw mine in the bin and bought a GH one - job done.
    West Bend, Wisconsin
    210
    Nice job. If I ever have issues with mine ill give that a try.
    Regarding the aluminum bulkhead; in my merv I have integy aluminum front and rear, and my wife has the gpm aluminum front only. Absolutly no issues thus far.
    2,334
    That's really cool. I would like to get aluminum bulkheads, but for $50 a piece, that's pretty expensive; about $100 for both bulkheads...
    USA
    457
    I just slid it on and it's very tight. I don't think it will ever move.
    Yes, I'm running the Integy aluminum bulkhead. They work very well and keep everything from flexing. FYI, you will need to use shims with this bulkhead.
    Jan 2010
    Ukraine
    565
    have you tried to just put a screw that holds the pin on threadlocker?
    i wonder if this will work
    My mini E-Revo.net and the BIG ERevo.net
    Nastyville Tennisshoe
    341
    I had the pins come out all the time. messed up my chassis too! I welded the pins in! and ground them flush!
    Also the drive cups on the dog bone sides are too soft, the dog bone is wearing through the cup!
    let us know if and when you strip out a the ring and pinion in those bulkheads. I hope they cure that problem and will get them if it does! I think the main problem with stripping the diffs are that they are made of cheap pot metal!
    54
    nice mod! looks very reliable.
    Electricity is really just organized lightning.
    USA
    457
    Quote Originally Posted by Angrytetsuo View Post
    I actually just replaced the drive cup. I'm still using the stock driveshaft up front, so I used the second Integy drive cup as a spare. I haven't had a diff failure from any other issue other than the pin coming out.
    341
    Quote Originally Posted by fastmachine View Post
    heres my turd - http://www.youtube.com/watch?v=SxajgDtdzQQ
    Feb 2002
    9,366
    for the op, did you slit the pipe lengthwise? it looks as if it was slit in your picture
    USA
    457
    Quote Originally Posted by jimbo74 View Post
    That's the way it came.
    Quebec
    374
    Can you please provide feedback on this mod after testing it for a while?
    What have you learned today?
    Slovenia (EU)
    63
    i would be also interesting on feedback. I just got the integy shaft. Didnt know it had suck big problems :X
    USA
    457
    Quote Originally Posted by Papino View Post
    It has been running perfect. Although now, I'm running the GPM center drive shaft and I like it better. The GPM needs modification as well.
    http://traxxas.com/forums/showthread...er+Drive+Shaft
    Jun 2011
    Leeds, Yorkshire, UK
    46
    re gpm driveshaft, I just stripped it down and reassembled it using threadlock and have yet to have any problems all the pins have a flat for the grub screw to locate against so shouldnt come adrift now it is all threadlocked, I have been running it for around 3 months heavy use with mmp 5700/4600 combo's.
    Alloy bulkheads next mod as keep breaking the front one
