    waterloo .on.canada
    2,294
    Question can i charge two stock packs in
    Can i charge them in parellel at 2amps?
    Jun 2010
    Miami, Fl
    6,731
    I won't recommend it.
    Alma, Michigan
    12,314
    You will get false peaks.... parallel charging only works with LiPo's.
    Jun 2003
    We-Go, Chicago, IL
    2,867
    It worked fine with me when I was still running NiMH packs in mine. I'd usually charge them at 3 amps (although I accidentally did it once at 5 amps, luckily without problems )and the only times I had false peaking issues was on my Onyx 240 when the right side charger started to act up and has started to false peak with several different NiMH packs of various sizes.
    Aw, Biscuits!
    waterloo .on.canada
    2,294
    so from the top two replys i take it your going of of the cells and there seperate resistinces meaning that one pack gets a bigger charge then the other? there for needing a balencer
    waterloo .on.canada
    2,294
    okay ive had the batts for about a week and have charged them in parrellel the only problem so far for me is that every now and again they need to be charged sepret due to uneven charging
    Sep 2011
    Earth, Milky Way.
    928
    I would charge them in SERIES if your charger can do it.
    This is a signature.
