Page 3 of 3 FirstFirst 123
Results 81 to 104 of 104
  1. #81
    Jul 2013
    3
    I have a slash 4x4 with the docking station and all of the telemetry stuff hooked up. The dashboard has been working perfectly until today. Now when I turn everything on I get the two green linked symbols and everything is registering for about 20 seconds and then it drops the connection to the unit and the two icons go red. Does anyone have any suggestions?
  2. #82
    7,176
    Replace the batteries in your Tx (see if this works). When the cells get weak it seems to not register on occasions even though it shows full power from them.
    Another thing is close out the Traxxas Link App. If the batteries are still good. Hopefully this helps you.
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
  3. #83
    Apr 2014
    3
    I have iphone5. but May I connect to TQi with adapter(iphone)?
  4. #84
    Jun 2013
    Southern Alberta
    192
    Quote Originally Posted by Mr. Shin View Post
    Yes, but a real Apple adapter, no cheapy's
    I use my Iphone 5 all the time.
  5. #85
    Apr 2014
    3
    Quote Originally Posted by HeavyDtheOgre View Post
    Thank you sir~~
    unfortunately, I bought a cheapy one, so i couldn't connect at all.. lol…
    a real adapter is a real expensive one.. so.. I better wait until somebody sell it at cheapy price..lol
    anyway thank's again..
  6. #86
    Oct 2014
    10
    Hi, i am from the UK and needed some help, there is no one to contact from traxxas in the UK so thought i would try on here-
    1. Firstly i am wanting to buy an XO1 in the next couple of weeks but wanted to know if the docking station will work with an iphone 6 plus or ipad mini?
    2. Will the base clips at the bottom of the base that hold the device hold an iphone 6 plus or an ipad mini?
    3. Which are the best batteries and chargers to start off with? im not going for 100mph straight away and would rather start off on 2x 2s lipos to get used to the car.
    4. What upgrade/mods can be done on the car?
    Ps i have seen a video online where the docking station has been modded to hold an ipad mini- has anyone else done this? And how?
    Thanks
  7. #87
    Jun 2013
    Southern Alberta
    192
    Quote Originally Posted by mits-88 View Post
    Thanks
    The iphone 5 & 6 will work if you get the real Apple 30 pin to Lightning adapter - NO cheapies!!!!!
    The Iphone 6 is also wider so I don't suggest clamping it tight with the stock adapters - I don't.
    As for batteries, I use the Traxxas 11.1v 5000mah batteries(came with car), Traxxas are really good batteries, I have bought more since for other rc's.
    & as for mods - the steering needs to be modded - go here - http://traxxas.com/forums/showthread...4-My-XO-1-mods
  8. #88
    Oct 2014
    10
    Hi thanks for the reply could you confirm if you have IOS 8 on your iphone and does that work with the TQi? Traxxas said it is only compatible with IOS 7 but the main UK distributor says it is compatible, i dont know who to believe.
  9. #89
    Jun 2013
    Southern Alberta
    192
    I have IOS 8.1 & it works just Awesome, cause the iphone 6 faster processors.
  10. #90
    Oct 2014
    10
    Hey thanks so much ive been asking everywhere and your the first person to confirm that you can use ios 8, i must have rang everywhere! Can you use all the features as normal eg the dashboard? Is it the new system that connects with bluetooth? And is it used with an xo1?
  11. #91
    Oct 2014
    10
  12. #92
    Jun 2013
    Southern Alberta
    192
    I use mine with 2 - XO-1's, slash's, & others.
    & the new app can Bluetooth, but none of mine are.
    & everything functions in the app.
  13. #93
    Oct 2014
    10
    Kool thanks for confirming that i can now finally buy one! I have the iphone 6 plus so im going to mod the base of the controller to hold the phone or may even mod it to hold my ipad mini as i have seen others on youtube do this and i dont have to worry about the connection as i will do this via bluetooth, im glad you confirmed it will work with ios 8 as when i emailed traxxas directly they said it would only work to ios 7 and the UK Distributor said it would work with ios 8 lol
  14. #94
    Oct 2014
    10
  15. #95
    Apr 2015
    9
    Hi guys
    I have an xo1 with the TQi transmitter which runs the Apple dock, however, I cannot connect my android phone to this which meets the minimal software requirements (i.e. android version 4.4 or newer, mine is 5.0).
    Does the above only apply to the Bluetooth version transmitter? If so, I may need to buy the Bluetooth transmitter...fyi, my iPad does connect to the dock with no issues.
    In case you are wondering, I bought the adapter which is a female 30 pin Apple socket to male micro usb, as per below link:
    http://pages.ebay.com/link/?nav=item...316846&alt=web
  16. #96
    20,547
    Android is only supported by the Bluetooth version.
    Alt-248 on the number pad =
  17. #97
    Ontario
    666
    Will the new tsm rec n remote work
  18. #98
    Ontario
    666
    Sorry better question
    So I already have a Bluetooth remote but it's non tsm model
    So was wondering if I buy a tsm receiver will they work together ?
  19. #99
    Oct 2015
    983
    Quote Originally Posted by traxxaspro View Post
    Yes, you can. I did it. I made a video of it, but haven't had time to edit and upload it.
  20. #100
    Dec 2017
    11
    Yes, But into a wall
  21. #101
    RC Qualifier kzsteve's Avatar
    Jan 2018
    norcal
    325
    question : I have a iPhone 4 . what adapter do I need for the phone to my TQ1 ? ............. thanks .. steve
  22. #102
    Feb 2018
    Can the telemetry ports on the RX be used to power on the Traxxa LED light kit? Or anything else other than telemetry?
  23. #103
    Jan 2018
    norcal
    325
    new problem . can not get the receiver to recognize the transmitter . red lights is all I get . tried many way with no luck . any ideas appreciated ........... steve
    XO-1 GUY GETTING OLDER BY THE MINUTE
  24. #104
    Jan 2018
    norcal
    325
    got it running great . all things work .... except my iPhone will not read temp or rpm . need ideas .......... steve
