Results 1 to 10 of 10
    61
    Bec in my summit 1/16
    Hi I have a summit 1/16 with the stock servo and I have an extra cc bec lying around and wonder if Itd be a good idea to put it in truck?
    Sent from my DROIDX using Tapatalk
    12,314
    I really do not see any benefit.
    The stock servo is not a power hog by any means...
    RC Racer MaxxPain's Avatar
    Aug 2007
    NorCal
    185
    I think you would see a difference as you could get 6 volts to it vers 4.8 from the ESC. Plus the external BEC would offer more amps over the stock ESC. Not sure how man amps the stock servo could pull even at 6 volts. But I run them in my crawlers and I see how much they offer. Throw it in,, I say.
    Xmaxx, Rally, Slash 4X4, Summit 1/16
    12,314
    Where did you get the info that you only get 4.8v to the servos?
    Aug 2007
    NorCal
    185
    I was assuming but after checking the specs I am wrong. http://traxxas.com/products/parts/escs/vxl3m It does say 6.0volts but does not list amps. I actually have a watt meter for my airplanes. I'll see if I can plug it in and get a reading on what amps it pulls when operating the servo.
    Jul 2007
    Rc Room
    1,482
    Couldn't hurt anything, chuck it in there and tell us how it works.
    12,314
    Thanks for clearing that up, MaxxPain.
    Alberta Canada
    1,067
    Quote Originally Posted by MaxxPain View Post
    Have you tried? I was looking at getting a 6-7.4v High torque metal gear servo, after 3 dead stocks i'm getting something better but I don't know if the stock reciever will supply a more powerful servo.
    12,314
    Yes it will... especially a 16th sized servo.
    My Summit has 5 servos... two of which are 400+ in/oz torque monsters. The stock receiver had no issue having the current traveling through it.
    The real question is if the internal BEC of the ESC is up to the task.
    Aug 2007
    NorCal
    185
    Have you tried? I was looking at getting a 6-7.4v High torque metal gear servo, after 3 dead stocks i'm getting something better but I don't know if the stock receiver will supply a more powerful servo.
    I'm sorry, I have not measured it. I keep forgetting to bring it home.
