Page 2 of 2 FirstFirst 12
Results 41 to 55 of 55
  1. #41
    Jun 2011
    408
    the blue anodized is item 110730374029
  2. #42
    Jun 2010
    Australia
    363
    Weird... I can find it with the item number but not when I use 2 key words in the listing title.
    Slash 4x4
    Spartan
    Stampede
    Rustler x 3
  3. #43
    Jun 2010
    Australia
    363
    I should also add that I'm searching worldwide and in all categories.
    Slash 4x4
    Spartan
    Stampede
    Rustler x 3
  4. #44
    Jun 2011
    408
    To find these items type in Traxxas Spartan for your search
  5. #45
    El Cajon Ca
    1,805
    Troy711 I sent you a PM. Hope it helps....
    "enjoy your ride"
    Dennis
  6. #46
    Sep 2011
    Alden, NY
    158
  7. #47
    Jun 2010
    Australia
    363
    Cheers for the help. I think the reason I couldn't find it was because they don't ship to Australia for some reason.
    Slash 4x4
    Spartan
    Stampede
    Rustler x 3
  8. #48
    Mar 2018
    Is the dual water pickup still needed with the new Spartan? Would the aluminum cooler be enough with the T?
  9. #49
    Eastern Shore, Maryland
    3,962
    If you want to run 6s then you need at least the aluminum motor water jacket, and the dual rudder with separate water lines going to your motor and ESC.
  10. #50
    Jan 2018
    Mansfield Ohio
    33
    I'm alittle confused by the water outlet myself I bought the OSE dual water outlet it shows as far as I can see that 4 holes need to be drilled. Would I be better to get a traxass outlet and just drill one hole and should I ( if that's what needs to be done ) drill it on the opposite side or next to the original hole ?.....Also got the water jacket and dual rudder.I am dying to get this thing in the water.
  11. #51
    3,962
    That's what I did with my Spartan. I have a OEM water exhaust port on each side, but even with the OEM ports you will need to make two holes. One for the securing nut and the other one for the port itself.
    The only way you can get away with drilling one hole per port is by using what's used in a UR-19 or Blackjack29. They both use single hole exhaust ports.
  12. #52
    Jan 2018
    Mansfield Ohio
    33
    Another question for you ...Did you use the same size tubing for the lines you ran
  13. #53
    3,962
    Another question for you. Did you use the same size tubing for the lines you ran?
    Yes, they are different colors and stiffness, but they are the same size tubing. I use Traxxas OEM BLUE for the ports, because it's easier to get them on/off for maintenance. I use the YELLOW tubing strictly for looks.
  14. #54
    Oct 2015
    Missouri
    176
    Quote Originally Posted by Troy711 View Post
    Can someone post a direct link to the splash guard on eBay (or just the item number) cos I still can't find it.
    Just type "Traxxas Spartan splash guard" in the search area. The hot racing guard will show up, I found it for $12.88 with free shipping.
  15. #55
    3,962
    You should just get it from Steve from Off Shore Electronics. It's very easy to do.
    https://www.offshoreelectrics.com/pr...prod=dh-spn30g
