    Nov 2011
    94
    Hi guy's! newer member with some 1/16 summit questions!
    Alright, So i have 2 of the 1/16 family line. A merv that became a slash sorta... And a Summit, I picked them both up used in 2 seperate transactions.
    The merv needed a Ton of work. I recieved it with a Broken rear a arm and all joints worn out!
    The summit is in much much better condition. I am truly enjoying it. Altho it doesnt go in snow as well as i thought it would.
    My questions are Trans flip guys? are you happy with it?
    Speed?
    Torque?
    I am planning on almost locking my rear differential on it and having a semi open front. Waiting on my shims to get in
    Also What gearing do you guys recommend?
    Lastly. Aluminum carriers? or plastic? i see arguments for the rpm? some say good some say not from my lurking. I don't like buying same parts over again. And i really need new pivot ball mounts especially on summit! Thanks guys Also cheap steering servo recommendation's or go back with 2080's?
    Alma, Michigan
    12,314
    Transmission flip and speed do not mix well. The gearing is way low... creating massive amounts of torque.
    In my opinion, go alloy for your knuckles. GPM or HR seem to be the best.
    If you want to keep replacing servos, keep getting stock ones.
    If you want to buy replacements once, get a ******* 390. I have in each of mine and love it.
    Nov 2011
    94
    So do not flip transmission period? or? I tried searching for video's of it on you tube. I have seen one where it shows how to but thats all
    Alma, Michigan
    12,314
    If you are building up a straight "crawler" it is not a bad idea.
    If you want it to go fast, flipping is hindering you more than helping you.
    Nov 2011
    94
    Well i have the merv/slash for lotsa speed id like the summit for a trail truck but i would still like it to go atleast 15 mph or so. i gues i will flip it and find out
    Alma, Michigan
    12,314
    15 should not be a problem.
    Nov 2011
    94
    I swapped it over and tons of torque as jimmy said, crazy wheelies have about 4 inches of snow so cant really test top speed
    I am getting probably 10 mph maybe a lil more it will wheelie with ease.
