Results 1 to 17 of 17
Thread: MERV shocks
    Saskatoon, Canada
    25
    MERV shocks
    I am wondering what everybody MERV shock setup is? Which springs and oil weight do you use?
    Thanks,
    Clay
    Central N. Carolina
    953
    I run the Black & Tan springs with 60wt oil...it could use heavier weight oil in the back though but then again you gotta think the higher it sits the easier its gonna roll over
    Saskatoon, Canada
    25
    Thank Devildog.
    Jun 2010
    Springfield, Ma.
    3,379
    The oil weight slows the chassis or stops it from slapping the ground, higher the # weight the thick and in turn stiffer the feel. The springs and adjustment ring decide how high/low the ride height and aids in the shocks rebound. So you find a sweet spot ....oil that's thick enough to stall the impact but still let shocks rebound matched by spring that lifts the truck to your hight with out adding bounce from to much rebound.
    Saskatoon, Canada
    25
    So I am using the stock springs in my brushed MERV, tan and black I think. I have set my preload to acheive my desired ride height, but I noticed that when the springs are compressed they dont return my merv to my desired height. Do I need to get stiffer springs? Or change the oil? I do know that the cold weather does changed the viscosity of oil. I am also using long travel rockers. Any advice would be awesome.
    Thanks,
    Clay
    Springfield MO
    252
    U need stiffer springs if u have the stock springs they are green springs all the way around get some tan an black springs with 60 or 70 wieght oil an u should be at a good starting point on ur handling
    514
    I'm using the black springs all the way around with 80wt shock oil. The car will most likely never rebound to its maximum ride height, it's best for the suspension to sit at about 2/3 the max height. Shock oil will not affect the ride height, it's simply a shock dampener, but the spring/preload adjustment will affect the ride height.
    Southwest MI
    81
    What are the stiffest springs available? I've seen black and double black on ebay as well, what's the difference? thanks
    28
    Anybody got a link for a spring rate chart that is color coded?
    2,435
    Quote Originally Posted by bashaslash View Post
    when you go on tower hobbies and look at each spring it says in the specs there rate....
    Central N. Carolina
    953
    You can get the summit springs, do a ebay search for '1/16 summit springs' i think they are 2.77-3.2 rate.
    I'm know there are other stiffer ones but I have just never looked.e
    Saskatoon, Canada
    25
    So correction, I only have a MER!!!! (Mini E Rev) So Im have tan springs in the front, and black springs in the back. So if Im understanding correctly, the oil helps to dampen any bumps, the springs raise the ride height back to 2/3 of the preload. But one thing I dont figure out is how the spring rate is figured out, and what the figures mean. If you want a higher number or a lower number. Im guessing it depends on what you are trying to accomplish. What is the stock oil weight in the springs?
    Thanks guys,
    Clay
    Feb 2002
    9,311
    i run ace hardware springs and 5000 wt diff oil
    Saskatoon, Canada
    25
    whats the benefit to "ace hardware" springs?
    Feb 2002
    9,311
    Quote Originally Posted by woog420 View Post
    they are a lot stiffer than any of the traxxas springs out there... and they were cheap and readily available
    i have heard the gpm stiff springs are pretty good as well, i think they are about equivalent to the ace hardware springs i run
    Jun 2019
    9
    Quote Originally Posted by devildog88 View Post
    "if it ain't broke, you're doing it wrong" nice, how do i put my own?
    Jun 2019
    9
    Quote Originally Posted by jimbo74 View Post
    You do NOT run 5K wt oil. do you mean 50?
