Results 1 to 21 of 21
    Boogie Down BRONX
    371
    Chewed up pinion
    I was wondering if this has happen to anyone else with there pinions gears. It looks
    like Jaws was chewing on my pinions like bubble gum. Is there something that im doing
    wrong or is this mormal wear and tear. Its the pinion in the center.
    Thanks..
    BASH!! BASH!! BASH!! & BASH IT AGAIN!! <CAGE RAGE>
    Jul 2011
    513
    Pics not working I use photobucket.com work well and its FREE and you can upload pics right from your phone.
    4x4 Slash 5.5 Big Block
    North Florida
    676
    you wouldn't be using a metal spur would you?
    that thing looks like a sprocket for a chain drive now
    Jul 2011
    513
    WOW are you using 32 pitch pinion gears and like iamsuperbleeder stated you using a metal spar gear ???? I had metal gear on my mini losi hate them. after i removed the metal gear
    Boogie Down BRONX
    371
    No im using the plastic traxxas 52 spur on a 3s. that pinion is or was a 19.. do you think the mesh is to tight
    i tried the paper method and the feel method.. im confused
    Jul 2011
    513
    Use a wax paper in between the gears them tighten the motor This works for me.
    Houston, TX
    627
    it might be your gear mesh mine has been doing that ever since i switched to 3s and im pretty sure it was the mesh but i think i got it this time around just havent checked yet
    Boogie Down BRONX
    371
    Ill try that tomorrow im getting some new wheels in the mail.
    also that spur lasted me a month all i do is bash i thought i was
    light on the trigger. lol guess not..
    Quote Originally Posted by jay janak View Post
    20,070
    Never seen it that bad. The pinions are steel, right? They don't look like the hardened version though.
    Alt-248 on the number pad =
    North Florida
    676
    I've always used regular paper, a thin strip folder over to double it up, and the mesh seems to be dead on every time
    13,246
    I have had that happen. It was the combination of a tight slipper and gear mesh to tight.
    Jun 2010
    Australia
    363
    I minced an aluminium spur gear on the first run I used it on. I thought it would last longer but looks like I'm back to plastic now.
    Slash 4x4
    Spartan
    Stampede
    Rustler x 3
    Boogie Down BRONX
    371
    I Forgot to mention that those opinion gears are fRom Robinson Racing. When i had to change the gear i had to replace the spur also
    i thought they were the strongest material for gears. I bet it might be my meshing Im hoping its my meshing. LoL
    Either way Im just glad its an inexpensive part. I still like the Robinson Racing brands.. Thanks all for the advice
    Ontario, Canada
    1,191
    Just to be sure, check your motor plate and mount as well to see if it isn't cracked and that your motor alignment is good.
    Boogie Down BRONX
    371
    Quote Originally Posted by Tallguy905 View Post
    Ok thanks ill check for cracks and if there is any unalignment..
    3
    yea i dont know i seem to have that problem alot
    Boogie Down BRONX
    371
    TallGuy I finally got around to working of my Rig. You where right on the money!!! As im cleaning
    my slash i noticed one of the screws that holds the motor to the motor plate was loose
    i could move the motor up and down alittle so that was allowing the motor to have a
    tight and loose mesh causing my pinion to look like JAWS was chewing on bubble Gum
    i tried to tighten up the screw but the head is stripped. hopefully good old BLUE can help
    me out if not ill have to get creative.. Thanks Tallguy and everyone else for the help.....
    13,246
    Glad you found the problem!
    9
    i just ran into the same problem screw was loose . i was able to tighten up the screw(seems like those heads strip easy) had a hard time getting it back but did... only problem now seems like motor isnt align just right. when i spin tires the gears roll and studder stop then roll again.. should i adjust gear mesh?
    Dec 2009
    MN
    793
    Try Robinson racing absolute pinions.
    Slash 2wd Sand Rail
    Slash 4x4 MT
    P4de Trail
    Boogie Down BRONX
    371
    Quote Originally Posted by wedoitall View Post
    Yeah before you do that make sure that the motor is snug to the plate. Then mesh it up
    If the motor is loose on the plate you'll never get a good mesh plus you'll tear up spurs
    And pinions like crazy. As for the striped screws try to find a different size what i mean
    by that is try using a mm wrench or a metric wrench so that its a snug fit. I kept striping
    Screws cause i was using the wrong wrench it would fit but not like its suppose to fit..
    No more striped screws.
