Results 1 to 14 of 14
    Enterprise, AL
    35
    How to put pillow balls back in
    Truck took a little tumble today and both of the pillow balls popped out of socket on one of the front wheels. How do I put them back in? Searched here and google and came up empty. I tried a little with a set of pliers but didn't want to damage anything. So I'll wait and let someone smarter than I explain the process to me.
    Thanks in advance for any help!:
    Slash 4x4 x 2
    E-Maxx 3903 CC brushless
    N. Idaho... Da Sticks!
    7,690
    There is a hex-key slot on the opposite side of the threaded portion. They shouldn't have just pooped out, you either had them too far out, or your arms are stripped and need to be replaced.
    Jan 2001
    Fresno, CA
    2,018
    On the outside of the knuckle there is a big hex thread that out. also thread the ball out of the arm. The ball inserts from the out side Threw the knuckle then the big hex (bushing) threads back on don't over tighten the bushing it will bind up the suspension
    Sent from my secret hiding place AKA the garage.
    3.3 t-maxx, O.S. .18TM t-maxx, HV brushless e-maxx
    Enterprise, AL
    35
    Perhaps i didnt explain very well. The balls were still both screwed into the a arms but they dislodged from the sockets at the end of the cv.
    Thank you. I was wondering if that big hex might come off but didnt investigate since the football games were starting. Ill give that a try but sounds like you knew exactly what i was talking about and this sounds like the ticket to repair my truck.
    Slash 4x4 x 2
    Columbus, OH
    187
    Chances are that if you pulled the pillow balls out of the axle carriers, the axle carrier will have a hairline crack in the housing and you'll need to replace it.
    Enterprise, AL
    35
    Ill check.again but they looked intact. I was amazed. Thanks for all the help.
    Slash 4x4 x 2
    Sep 2011
    1,350
    Quote Originally Posted by HighDollarRustler View Post
    +1 ^^^^ What he said.
    7,690
    Ok, that makes sense. Even if there is not a crack in the carrier, this problem will be chronic until they are replaced. This is a great time to upgrade to RPM carriers!
    Oct 2011
    461
    Just order some 5334R traxxas part number they have a metal insert the balls wont pop out ever again the RPM'S dont have the metal insert. I like rpm products but they need to update there axle carriers. And dont forget to put the R at the end of the part number
    I BLAME ALL THIS ON POPOXX!
    Enterprise, AL
    35
    Hey I love having a reason to upgrade! I was having to cool it a little since I just put RPM A-arms all around with bulkhead braces. I think I'll take your advice and order the new parts and if/when they pop out again, I'll replace them. Thanks.
    Quote Originally Posted by MAYHEM6969 View Post
    I like RPM also and would have probably just blindly ordered their axle carriers as a result. Thanks for the tip.
    Well no cracks so I put them back together as is. Steering bellcrank is broken though so I went ahead and ordered that along with the upgraded Traxxas axle carriers.
    Took your recommendation Mayhem. Thanks.
    Quote Originally Posted by likametal View Post
    Appreciate the help. I just wasn't seeing that the inside of the axle carrier was threaded. Anyway, thanks!
    Slash 4x4 x 2
    Jan 2001
    Fresno, CA
    2,018
    no problem i never have pulled a pillow ball out like you did. but i have had my maxx apart enough to know what you ment
    Jul 2010
    235
    I had same thing happen on mine, I clipped my truck's tire at speed and the emaxx tire caught up under truck tire. as maxx spun around it ripped pillow ball right through back of carrier. Mine did crack and after putting back together it came right back out on the slightest crash. I'm glad parts are cheap
    Your signature is not appropriate Please change it
    Sep 2010
    38
    Quote Originally Posted by lgwilson View Post
    Did you have a problem with the lower front RPM A-Arms? My steering bellcrank(?) was hitting the A Arm/hinge pin and keeping it from turning. I had to shave the arms way down to make them skinny enough. I had already replaced my bulkheads with aluminum bulkheads so maybe that had something to do with it too?
    Enterprise, AL
    35
    Quote Originally Posted by bmccle View Post
    No problems like that here. I used RPM everything. I.didnt drive the truck today with all the rain here but i turned it on and the steering looked and sounded good.
    Slash 4x4 x 2
