Results 1 to 16 of 16
    14
    Installing new TRX 2.5R in my MAXX. NEED HELP
    Hi, I am trying my hand at installing a new engine in my Maxx truck. Do I need greese or oil to put this back together?
    Thanks for your help...
    EM SO.CAL
    456
    Are u putting the engine together or just installing onto the maxx?
    Usquam sed hic
    1,570
    If you're just putting the engine into the truck you don't need any kind of lube.
    If your assembling the engine itself, you'll need some after run oil for assembly lubrication.
    Matthew 7:7
    14
    Just installing into the truck, but I am putting the parts on the engine for the trans
    RC Turnbuckle Jr. fantomaxx's Avatar
    Apr 2005
    socal
    3,095
    no oil or grease needed.the oil for engine is in the fuel.after your done running you set piston to bdc,use afo or wd-40.
    454 bb maxx
    EM SO.CAL
    456
    So your talking about the flywheel, clutch, and bell?
    14
    Thank You very much!
    14
    yes, I am trying to put the parts on the engine itself
    14
    So no lub for the parts that go on the engine EMRaiders81?
    EM SO.CAL
    456
    no not to put those parts on.
    EM SO.CAL
    456
    Install flywheel, flywheel nut, clutch, bearing, clutch bell, bearing,washer, e clip and your done
    Nova Scotia (Eh!)
    421
    Hey,
    When you assemble the internals of the engine you must USE oil. If it's just parts like flywheel or the backplate then it is not necessary.
    back
    14
    My last engine was a trx 2.5 and the new one is a 2.5R. I have the engine on the chassis but the Carb is on backwards. can I turn it around?
    Apr 2005
    socal
    3,095
    ya you can turn it to the opposite side.
    454 bb maxx
    14
    cool, thank you
    Jun 2009
    Cocoa Florida
    4,909
    Just make sure the bottom carb neck o~ring is in it's grove, a little lube on it will help the carb body slide into place easily & reduce the chance of rolling the o~ring out of the groove.
    The rest of the parts need no lube for assembly.
    Look out for the tree/crunch!
    LiPo? Naw NITRO!!
