Results 1 to 3 of 3
    Dec 2008
    Turn Buckle Wrench
    What do you use to change the length of your turnbuckles? The wrench that comes with the truck
    is so hard to use and doesn't grip on it correct and you can only get about a quarter of a turn.
    thanks for your input.
    Southeast Michigan
    With any other 4mm wrench it's not like you'll get any more travel...
    Plus, when you adjust camber, 1/4 of a turn could be about 1/2 degree (probably a bit less, but you get the point)
    SSC SLASH 4X4 (Long gone...)
    Slash 4x4 PE LCG
    Feb 2010
    The wrench that you use to tighten the slipper will also work.
