    8
    Receiver & Transmitter problems
    Hey there! I am having an issue with my traxxas Link receiver and the 2.4gz transmitter. I was driving my rally in my basement when all of the sudden the car braked and I lost control. I took of the body to find the link receiver blinking between green and red lights very fast.
    I looked in the manual and thought that It may be a problem with the bind. And so I tried to re-bind the system but when I do the steps:
    Hold set, then turn on transmitter. (red light blinks slow)
    Hold link, then turn on esc.
    I get a green light on my transmitter, with a slow blinking red light on my receiver. I have let this go on for about 10 minutes and the problem still stands. I also have a green light on the ESC
    Anyone know what I can do? I've read everything in the book and I can't call traxxas support because I live in Canada.
    Much appreciated!
    Little update, I have been searching some old posts and some people find that it is because the steering servo is broken. I tried to do a bind without the servo plugged and and it worked fine.
    Alma, Michigan
    12,314
    Awesome! Glad you got it under control!!
    Let us know if you need help finding a replacement.
    8
    Turns out the servo fried and that was what caused the lack of reply between receiver and the transmitter. Threw a new servo in there and everything worked just great! While I was reading up on that problem I seam to find that this is a problem that occurs quite often with these servo's so a few suggestions for a better replacement would be awesome!
    Alma, Michigan
    12,314
    Here is a list of servos... keep in mind not all of them are an upgrade:
    http://www.servodatabase.com/compare...1677,2119,2130
    I chose the ******* 390 (same as a blue bird 390) for my two 16ths.
    IF you go the 390 route, here is how to set it up:
    390 Set Up
    All stock hardware is used.
    NONE of the hardware included is needed!
    There are tab braces that do not allow the servo gaurd to sit flush.
    IT IS OPTIONAL TO REMOVE THEM.
    I have done this both ways without any adverse reactions.
    Here is a picture of the braces:
    The only reason this may need to be done is because of the small gap between the chassis and the servo gaurd.
    You will also need to reverse the servo direction.
    These are the steps to follow to do so:
    (Traxxas LINK)
    Hold MENU
    Green Blinks
    Press MENU
    2 Green Blinks
    Press SET
    Green Blinks
    Press SET
    Red Blinks
    Press SET
    8 Green Blinks
    Hold MENU
    Setup Complete
