Results 1 to 8 of 8
Thread: 3s lipo
    MIAMI FL
    152
    3s lipo
    Can I run 2 3s lipos in parallel with out doing damage
    TO MUCH TO LIST ON HERE
    12,314
    If you follow the directions in the manual for Series running, no.
    Lilydale, Victoria, Australia
    2,843
    Running parallel packs (2s or 3s) is fine, simply doubles your runtime
    Cheers
    Slash Platinum
    Xerun 150 / Tenshock SC401 3500kv
    Feb 2002
    9,352
    he said parallel.....
    but.... be careful on stock electronics running 3s for ewxtended amounts of time.... that heat build up can easily fry them if the vehicle isn't properly setup
    12,314
    3S is close to NiMh series in voltage.
    2,843
    Stop confusing the fella, he asked if 3s packs can be run in parallel
    The answer is yes
    Obviously he needs to gear the car for 3s to avoid heat issues
    Cheers
    Slash Platinum
    212
    Im about to do the same thing. (Two 3s lipos in parallel) What is correct gearing?
    2,843
    Included speed pinion (23t) is a good place to start
    You may even need to drop down to a 21t
    Cheers
    Slash Platinum
