    Sep 2011
    College Station, Texas
    96
    How to use Castle link on mmp sct
    Do you have to get the Castle Link USB Programming Kit to program the mmp sct, because in the drivers ed book that it comes with it says that mamba escs have a usb plug built in but i can't find it?
    Jun 2011
    221
    Yes you must get it...
    Stromsburg, NE
    142
    I think the mamba monster has the port. on the mmp you unplug the wire from from the rx and then either buy the castle adaptor or the field programming card and plug it into them. Then there is a mini USB port on each if those.
    Hope that helps
    Sent from my DROID BIONIC using Tapatalk
    Sl4sh with CC MMP 3800, 2 mervs, a 3905 BL eMaxx,
    Lilydale, Victoria, Australia
    2,843
    Only the older Mamba Max had a built in USB port, every other Castle ESC requires the adapter
    ESC can be manually programmed for most functions, but the software makes life a lot easier
    Cheers
    Slash Platinum
    13,186
    You might as well get the field link. You don't need a computer to adjust it. You can then plug the USB into the field link to connect it to your computer. It's around the same price.
