Results 1 to 14 of 14
    Edmonton, Canada
    4
    My 1/16 E Revo won't go forward.
    I just fixed my e revo's knuckles and when I went to test drive it the car didn't move like it had its own
    Feelings and didn't want to go. When I turn it on the light on the esc blinks red and green really fast.
    Any help please?
    Jun 2010
    Lancaster PA....... NO i'm not Amish
    321
    If you have the VXL car it's saying according to the manual that your esc is over voltage protection and it will cut power to the motor. What is you battery setup?
    page 17
    http://traxxas.com/sites/default/fil...l_100205_0.pdf
    MERV VXL + Rally VXL + Stampede Xl5
    1,717
    Is it in lipo mode?
    Edmonton, Canada
    4
    I really don't know I just got it and I don't know much about cars. I know that I might have charged longer than I should have and i have 2 batteries in it that might be over chargerd
    Edmonton, Canada
    4
    No as I said I don't know much about rc cars.
    1,717
    Are you hooking them up in parallel or series?
    Edmonton, Canada
    4
    i dont have a vxl. i have a brushed motor and have the batterys in parallel.
    14
    Yeah the batts are nimh, in parallel (double life, not double voltage) the esc got replaced under warranty, car has 2 hours on it and is like new.
    When the old esc went bad it just took off when turned on. Now it steers, but the motor makes no sound and wont go.
    This is NOT A VXL its his first car.
    It blinks very fast red. When turned on it is solid red, once the trigger is touched it starts blinking fast
    EDIT - when only one batt is on it works fine. Sounding like you overcharged you expensive toy kiddo . Take better care of your toys and read your instructions. Mom and i arent made of money i did your homework for you, so now you will need to discharge those batts one at a time and charge em properly. Maybe ask mom and i what work we have to earn a smart charger unit? I have firewood to cut amd some truck repairs i could use extra hands with.
    Thanks for the help guy who mentioned overvoltage - you got me thinking and testing and the problem is sorted out.
    Ontario
    1,395
    hahah, easy fix, I did something similar when I first got mine..
    was just running it though and my truck wouldn't go forward just backwards, for almost a full minute then it just decided to go forward again..
    what causes that??
    6.25% /
    Feb 2015
    I have a e revo brushless 1/10 scale and it will not drive when I turn it on and it will make a grinding noise without the tires moving
    Feb 2015
    Any advise?
    Jun 2014
    Southern California
    6,447
    Check if your spur gear came loose. If not that, check your gear mesh.
    You really should make this thread in the 1/10th scale Slash forum or the 1/10th scale Slash 4x4 forum:
    1/10th Slash:
    https://traxxas.com/forums/forumdisp...-Traxxas-Slash
    1/10th Slash 4x4:
    https://traxxas.com/forums/forumdisp...p?73-Slash-4X4
    Welcome to the Traxxas forums!
    May 2015
    I have a 1/10 e revo brushed and it will go backward .but not forward.
    Jun 2014
    Southern California
    6,447
    Oops! I meant for you to check and post in the 1/10 E-Revo Brushed forums:
    https://traxxas.com/forums/forumdisplay.php?65-E-Revo
    Also, check if your spur gear came loose. If not that, check your gear mesh.
    Good luck and hope it's a quick, easy, and cheap fix!
