    wv
    171
    transmitter/receiver help
    ok so my slash wont go any further than 10ft with out losing connection anyone know why?
    14,936
    Which radio version do you have? Did the antenna wire break, or get shortened in any way?
    Ya can't polish fertilizer...
    2,215
    Do this and your problem should be fixed:
    Check your reciever and see if it got wet..if so take it out and let it dry for a day or so.
    Also make sure your antenna wire didn't get cut or damaged in any way.
    And...kind of a dumb question but are you extending your transmitter antenna all the way?
    wv
    171
    @rag6 its a 2.7 and no,@upbasher ill do that,and no i didnt shorten it but ill check for damage,and yes i extend it all the way it is bent
    14,936
    Do you mean with the 27 mhz crystals? If the antenna is not damaged, try to borrow another set of crystals to see if that fixes it
    wv
    171
    yes,and thier was a small amout of water in the crystals
    wv
    171
    dose it ,matter if the antenna on the controller is bent?
    wv
    171
    @upbasher it worked and its fine now thanks for all the help guys
