Results 1 to 13 of 13
    Sep 2011
    New Brunswick Canada
    238
    Exclamation My E Revo is down for the count...
    I bought a new E Revo brushless on friday. Rand it yesterday on the stock Nimh batteries, worked fine... lil slow but it worked. Today I charged up my 7.4v 2s 20c LiPo batteries, when I plugged them in, turned on the radio, then the ESC, the 3 lights on the ESC come on, and just keep flashing. Steering and throttle both dont work. One of the steering servos also seems to get very hot.
    Now I did plug in the Castle link, so it does link up fine.
    Would love to call traxxas, but I dont live in the US, so no toll free number for us Canadians.
    Any suggestions is greatly appreciated.
    Founder & Creator of the Mini Monsters RC group
    313
    with the programmer i would make sure LiPo mode is on, that all your servos are plugged in correctly, and if one is heating up, replace it. did you try the Nimh batteries again?
    Sep 2011
    238
    PROBLEM FOUND! I have a fried servo....
    313
    thats kinda what i was thinking. it should be ok for street use and light bashing with one traxxas servo. go try the Lipos and rip it!
    Sep 2011
    238
    Thanks. I did just that. Took it out to a huge parking lot for speed tests. Top speed for the day was 52km/h. Not bad at all for stock gears on 4s (two 2s 7.4v 4000mah 20c Lipo)
    Love this thing. Was worth every penny.
    411
    A set of 4000mAh 20C LiPo batteries only gives out 80 amps... a bit too low for the Mamba Monster ESC ...
    Sep 2011
    238
    Quote Originally Posted by Imprez View Post
    So, will that harm the ESC or Motor? I am planning on buying 2 new Lipo's and a second Lipo charger. If I stick with Traxxas, I'm going to buy the 2s 5800mah 25c Lipos but I am considering all options.
    kansas
    8,677
    watch you battery temps, the MMM will over work the batts, & easy on the brakes with ripple current & keep the stock grearing..
    next set of batts look at 5000 mAh & 30C (150 amps) or 40C (200 amps)..
    ( mah x c rating / 1000 = amps),
    The
    more amps the better / minimun of 120 amps.
    The ESC will only draw the amount of amps it needs.
    Higher the mAh the longer the runtime.
    For brushless systems 8000 mAh about 45 min & a 5000 mAh about 30 min.
    Times are longer for brushed systems.
    Batts in series double the voltage:
    2x 2s 20c 5000mah = 4s 20c 5000mah
    Batts in parallel double the mah capacity:
    2x 2s 20c 5000mah = 2s 20c 10,000mah.
    A temp gun is kind of a must have.....
    Hot motor + cool esc = under geared.
    Cool motor + hot esc = over geared
    Everything warm just right..
    Motor ~ 180/190*F maximum, ideally 140/160*F, temps can be 10* higher inside the motor
    ESC ~ pretty much same temps / Fan comes on @ 150*F
    Lipo's ~ 140*F max, ideally 100/120*F
    Sep 2011
    238
    Well this day has been filled with not so good news, First my servo fries, still waiting to hear back from Traxxas Support on replacing it, and now the realization that my current lipo's arent the greatest for the truck.
    I do have a temp gun for sure. comes in handy.
    Well, looks like I will be shopping for new batteries. I did read the other thread about batteries and chargers as well. All excellent info.
    Sep 2011
    238
    So, If I buy Traxxas Lipos, I will be safe with:
    5800mah x 25c / 1000 = 145amps Cost $154 for 2 shipped.
    OR
    7600mah x 25c / 1000 = 190amps Cost $186 for 2 shipped.
    kansas
    8,677
    yep..............
    edit..
    This is a good start..
    Just don't buy no name Ebay batts...
    Besure to check sizing before you buy any batteries...
    In time some batteries will become discontinued...
    No particular order as to good, better, or best....
    2S
    With larger Lipo battery wires, you might need to - enlarge the exit hole on battery doors....
    or run wires out the vents..
    Direct Fit...........
    2s GensAce 5000 mAh 40c
    2s Gensace 5300mah 30c softcase packs
    2s HiCountryHobbies/Billowy Power 5200 mAh 50c
    2s Hyperion 5000 mAh 45C Soft
    2s RC DUDE Power 5000 mah 35c
    2S Sky Lipo 5000 mah 40C -- fit snugly
    2s SPC 5000 mah 25C hard case
    2s SPC 5200 mAh 40C
    2s SPC 5400 mAh 50C hard case
    2s SPC 6000 mAh 30C hard case
    2s SPC 8200 mAh 30c
    2s SMC 5400 mAh 50c
    2s SMC 6000 mAh 28c
    2s SMC 8000 mAh 28C Soft Case Lipo
    2s SMC 9000 mAh 28C Soft Case Lipo
    2s SMC 9200 mAh 50C
    2s Team Orion carbon 7000 35c
    2s Thunder Power 45-90c 5000mah
    2s ******* ******** 6000mah 25-50c
    2s Traxxas 5800 mAh 25c
    2s Traxxas 7600 mAh 25c
    Mod's.............remove retainers & back out or trim screws if they extend into battery compartment
    2s SPC 8200mAh/40C
    2s ******* 30c 5000 mAh soft - Extend Batt Door Out
    2S ******* 5200 mAh 5.2 Hard Case - Trim Batt Door For Wires
    2S ******* 5000 mAh 5.0 Hard Case - Trim Batt Door For Wires
    2s ***** ********* 5000 mAh 30C hardcase
    3S
    Direct Fit..............
    3s Hyperion 5000 mAh 45C Soft
    3s Max Amps -6000xls
    3s Team Orion Carbon 4700 mAh 45C
    3s Kypom K6 6000 mAh
    3s RC DUDE Power 5000 mAh 35c snug 29mm tall
    3s HiCountryHobbies Billowy Power 5200 mAh 50c snug 28mm tall
    3s ***** 5000 mAh 30c
    3s *********x 5800 mAh 30c
    Mod's..............remove retainers & back out or trim screws if they extend into battery compartment
    3s SMC 5600 mAh 50C
    3s SMC 5500 mAh 28c
    3S SPC 5200 mAh 40C soft case
    3s SPC 5400 mAh 50C soft-case
    3s Thunder Power 3s 45-90c 5000mah
    3s Traxxas 5000 mAh 25c
    3s ******* ******** 6.0 6000 mAh 25-50c
    3s ******* 5000 mAh 30c soft - Minor Mod/Extend Battery Door Out
    4S
    4s ******* 4000 mAh 30c - Minor Mod/Extend Battery Door Out (Same size as the ******* 3s 5000mah 30c soft)
    Traxxas link to batteries
    http://traxxas.com/products/parts/ac...s-applications
    http://traxxas.com/products/models/e...less-batteries
    battery compartment:
    Sep 2011
    238
    Hang on a sec, for the stock Mamba Monster esc is it setup in series or parallel?
    May 2009
    Edmonton, Alberta
    3,663
    the STOCK version in the ERBE is series.
