Page 12 of 12 FirstFirst ... 2101112
Results 441 to 473 of 473
  1. #441
    Half moon building out back
    730
    LOL Jimmie and you thought mine was bad. What I see looks OK but remember who is saying that
    Endeavoring to persevere !
  2. #442
    Alma, Michigan
    12,314
    Just found a problem... the servo will not work like I have it wired above. I just tested it... it MUST have a ground between the receiver and the servo as I suspected. But, if I do that I am concerned that the 7.4v system will effect the 6v system.
    Guess I will be doing some testing when my new multimeter comes in. My old one finally bit the dust after 15 years... lol
  3. #443
    Alma, Michigan
    12,314
    New meter came in today... I got right to testing!
    Tested by feeding 4.5 volts to a servo tester and feeding 6 volt direct to the servo. The tester was fed by a 3 cell AA pack I made just for this test and the servo was fed from a 2S pack via a 6 volt BEC. With just the signal wire connected to the tester the servo did nothing. With a ground wire from the BEC to the tester the servo worked fine... the tester was still only being fed 4.5 volts and the servo was being fed 6 volts. I then connected a ground wire directly from the 2S pack to the servo tester... same results; tester = 4.5v and servo = 6v.
    So, this new wiring guide should work out fine!
    All I have done is add a ground from the 7.4v power block to the receiver.
  4. #444
    waterloo .on.canada
    2,298
    all I can say right now is wow.
    and to think I will keep it simple on my own truck.
    keep up the good work jimmie
    summit /mustang /stampede-2s spc lipo
  5. #445
    Toronto
    2,440
    Great drawing btw, I've been trying to keep mine up to date with the three receivers and fpv gear, but these things are such a hassle to draw out cleanly like you have! Well done =)
  6. #446
    Alma, Michigan
    12,314
    Thanks for the compliment!
    It is just paint...
    Diagrams help keep me sane while I am soldering things up. I can do simple projects without drawing anything, but when it gets to look like a rats nest if I don't have a diagram to follow I tend to make mistakes.
  7. #447
    Feb 2013
    Montreal, Canada
    5,590
    Definitely following this, I will keep those connection iink in mind.
    By the way the internal BEC can be changed , ist it better to install one apart for a higher voltage servo or still run it from the ESC.
    Live life to the fullest
  8. #448
    Alma, Michigan
    12,314
    The stock ESC's BEC is not adjustable... it only puts out 6 volts. At first, I installed the CCBEC just to keep the ESC safe... I was pushing the limits of the BEC with the Blue Bird servos. Now, I want more power... and the steering servos are rated for 7.4 volt use so I am totally revamping the electrical on my Summit to allow two different low voltages to be used.
    My steering servos will be fed more voltage while keeping the 6v servos fed their limit as well as the receiver.
  9. #449
    Alma, Michigan
    12,314
    I have received some parts for my power strips/blocks!
  10. #450
    Alma, Michigan
    12,314
    I got my power blocks soldered up!
    I used an AA for size reference.
    There will be 3 in all; a 2 slot for the stock lights powered through switch A, a 3 slot for the under chassis lights and light bar powered through switch B, and a 3 slot for the steering servos and fan powered via the CCBEC at 7.4 volts.
    The 6v fan spins pretty quick on 7.4 volts!
    I have decided to start off powering the fan at the higher voltage... unlike the diagram shown above. If it fails rather quickly I will plug it in direct to the receiver as shown and solder up a 2 slot for the CCBEC.
  11. #451
    Alma, Michigan
    12,314
    Finally!!
    Proud owner of some sweet SPC packs!
    They do fit without cutting the fins, but it is so much easier on the wires if you do.
  12. #452
    15,211
    Jimmy, When I do get a summit, I am just gonna send it and the hacked flysky and all the parts to you so you can wire it... Wanna make some money???
    JK! I think mine will be a much simpler wiring job 8)
    Ya can't polish fertilizer...
  13. #453
    Alma, Michigan
    12,314
    Believe it or not, I sucked at soldering when I got back into this hobby...
  14. #454
    Alma, Michigan
    12,314
    Parts came in like 2 weeks ago... just haven't had time to tinker with it yet.
    I am bidding on some tires... hopefully I get them!
    (and get this wiring fixed up so I can actually drive the thing)
  15. #455
    Westford, VT, USA
    69
    Why did you go with the 6900mah 70c batteries as opposed to the usual 8200mah 50c batteries?
  16. #456
    Alma, Michigan
    12,314
    Because they fit in my other RC as well... a MT4G3.
  17. #457
    Alma, Michigan
    12,314
    Look what I found...
    $130 shipped for both sets!
    The Rok Lox are like new... the Moab XL's are well used in comparison, but I am not sure how much tread they came with new.
    Now to save up for some oversized bead locks...
  18. #458
    Sep 2009
    Victoria B.C Canada
    5,599
    The xl's.... that is a good score sir.well done
    Mountains cant stop me
    they have tried
  19. #459
    Alma, Michigan
    12,314
    I know!!
    How long have they been out of production?? Do you know? They have no rips or tears and seem to have very low wear... but without a new set to compare to it is hard for me to tell. I will be selling either the Lox or the XL's depending on which I like more for what terrain I am building the Summit up for... which is why I worked to get this auction; I should be able to sell the set I don't use and get most of my money back out of them. I am not one to have multiple sets of tires lying around waiting to be used for a specific terrain. I would rather have a tread that works in most terrain and use my hard earned money elsewhere.
    Elsewhere like my workbench... I really need to find the time/money to make a spot to work on my RC's. Hopefully this week so I can get the low voltage side soldered up and running on this thing before the summer is through.
  20. #460
    Jun 2013
    Birmingham, Alabama
    40
    Those are some nice tires! You bought them from me Haha! Funny I was just reading through here, and they popped up. What a small world. Good luck with them. Glad you like them!
  21. #461
    Alma, Michigan
    12,314
    Definitely a small world!
    Thanks for the honest description...
  22. #462
    Jun 2013
    Birmingham, Alabama
    40
    No problem!
  23. #463
    Alma, Michigan
    12,314
    8/72 gearing!!
  24. #464
    Newcastle, Australia
    969
    You planning to tow a house with that gearing? Should have plenty of torque!
  25. #465
    Alma, Michigan
    12,314
    I was one of the fortunate few to be able to test and review LEM's new dog carriers!
    I can see why LEM has no issues with giving these a lifetime warranty... the new carrier is immeasurably stronger than the stock one! I honestly feel you could literally turn the other transmission gears into dust, wipe off this carrier, and install it in your new transmission without any issues what so ever.
    Installation takes time, but is quite easy. The only reason I would rate it as difficult is due to Traxxas' design and how much is involved in removing the transmission. As far as LEM's carrier goes, it is as simple as removing the stock one and dropping in the new one.
    I took some time and made a few measurements...
    Fore and aft movement
    Stock: 4.5" or 114.3mm
    Modified: 2.75" or 69.8mm
    LEM: 2.375" or 60.3mm
    This was measured by rocking the Summit all the way forward, making a mark, rocking it all the way backward, and making a mark. Then the distance between the two marks was measured. Since there are many factors that would increase or decrease these measurements (wore axles, for instance), I took others as well.
    Weight
    Stock: 4g
    Modified: 4g
    LEM: 10g
    Weighed on my USPS certified scale.
    Degree of slop
    Stock: 117
    Modified: 28
    LEM: 9
    This was performed by using a stock cog and locking the carriers in full counterclockwise and then rotating them clockwise until they made contact.
    This is where it can be tricky... you really want near 0 play, but if you have too tight of tolerances, it will be difficult to reliably shift from high gear down to low gear or vice-versa. I believe LEM has chosen the correct amount of play... any more and there would be too much slop to really call it an improvement; any less and it would be frustrating to shift.
    Hope this helps!
  26. #466
    Feb 2014
    Greeneville, TN
    158
    Quote Originally Posted by JimmyNeutron View Post
    Weight
    Stock: 4g
    Modified: 4g
    LEM: 10g
    Degree of slop
    Stock: 117
    Modified: 28
    LEM: 9
    Hope this helps!
    Thanks for the update. It looks great!
    Summit Tacon 2650kv, 17/68, SMC 9400mah,Lem diffs
  27. #467
    waterloo .on.canada
    2,298
    With a tighter tolerance you said it would be harder for the dog to ingage. But what if it had more cut outs? I think there might be room for improvement on this.
  28. #468
    Alma, Michigan
    12,314
    It seems most of the pictures, at least for me, have stopped working. Too bad thread originators do not have the ability to fix old posts or I would do my best to make this thread complete again.
  29. #469
    Jul 2014
    Gold Coast. Australia.
    171
    Even with out most of the pictures it makes for a great read. Awesome build
  30. #470
    Apr 2014
    south jersey
    274
    I just read the whole thread and from the sound of things it sounds like you have quite an impressive build going on. I just purchased a summit yesterday to add to the traxxas collection. I seem to have acquired lol. Sadly though the only pictures I was able to view start from the cage you modified and installed. Wish I had been a member when this thread started and seen all the pics but oh well. Keep up the good work
    slash 4wd upgraded
