Thread: #2 Servo
    212
    #2 Servo
    I Just changed the first stripped stock one on my merv and was wondering is adding the second one as simple as some linkage underneath???? advice help????? ...if so what channel in the reciver do you plug it into ...
    Alma, Michigan
    12,314
    To add a second servo...
    You have to add linkage underneath
    There is already a second steering servo slot on the Rx
    BUT
    You have to find adjustable linkage and constantly tune the fight (to the death) out of the servos. I have a 10th scale Summit with twin steering servos. If you do not adjust the linkage to eliminate the buzz of the servos fighting each other to center, they will fry one another. Then you have to buy new servos....
    OR
    Upgrade to one super strong servo and then you don't have to worry about servos fighting to the death.
    I suggest looking into a 390... either by Blue Bird or *******.
    212
    and it plugs right into the normall spot????.......That sounds a lot better than buying new SERVOS ...
    Alma, Michigan
    12,314
    Yes, the 390 plugs right in... even uses the stock servo horn.
    Here is how to set it up:
    390 Set Up
    All stock hardware is used.
    NONE of the hardware included is needed!
    There are tab braces that do not allow the servo gaurd to sit flush.
    IT IS OPTIONAL TO REMOVE THEM.
    I have done this both ways without any adverse reactions.
    Here is a picture of the braces:
    The only reason this may need to be done is because of the small gap between the chassis and the servo gaurd.
    You will also need to reverse the servo direction.
    These are the steps to follow to do so for LINK:
    Hold MENU
    Green Blinks
    Press MENU
    2 Green Blinks
    Press SET
    Green Blinks
    Press SET
    Red Blinks
    Press SET
    8 Green Blinks
    Hold MENU
    Setup Complete
    212
    i will google it ......
    shoreline WA
    100
    the website that is not to be named. just google it.
